Volks AutosSky Insurance
Thread: N75 Orientation
    chasdrury's Avatar
    Jan 2005
    Sheffield, UK
    259
    N75 Orientation
    Hi
    Just replaced my N75 valve as i was losing boost sometimes - I replaced with a J version. The standard one was orientated like this - with the connector to the front of the car - the longer pipe going into the large pipe on the left as you're facing the car (i think the turbo intake pipe) and the one on the right goes towards the engine block.
    The J version - if orientated the same way - connector up at the front has the long pipe pointing right....
    Which is the correct way to fit it? I beleive that it does matter since it will overboost if not correct.....
    Please help!!
    Chas
    A4 2004 - 1.8TQ Limited Edition, 6 spd, Recaro Interior
    Mods - RNS-e (MK2); Rear Screens; PS2; AMI; Cruise; DIS; 18" RS6s; Carbonio CAI; Milltek CAT; Milltek CAT back Exhaust; Shark Stage 2 ReMap; RS4 RARB; HIDS; Auto Dim Rear View; RS4 Pedals, Gear Stick & Handbrake; Forge DV; Black Optics; Retro Fit Black Headlining; Retro Fit Power Folding Mirrors
    Mods to come - Memory seats; rear electric windows
    Andi25th's Avatar
    May 2010
    Inverness
    226
    Im all honesty send it back and get the proper valve for your car. Its not suited to your map and will make the car surgy.
    If you realy want to fit it fit it in the way the old one came out. The elecrical part will just be pointing in a different direction.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    long bit inot the tip, boost up the bottom and the other goes to the actuator. The car will overboost and go into limp mode more likely
    chasdrury's Avatar
    Jan 2005
    Sheffield, UK
    259
    I thought the J valve was supposed to make the boost come in earlier and go higher? Is that not right then?
  1. Star Performance Testing Day Pt4 N75s
    By Ess_Three in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2011, 14:57
  2. A3 1.8T power increase trhough N75 valve!!!!!
    By manueltrigo in forum General Technical / How To
    Last Post: 19th April 2004, 10:48
  3. A quick question on N75??? Valve
    By simondavidr in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th April 2004, 21:31
  4. WHATS A ECS N75 VALVE ??
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th August 2003, 12:05
  5. N75 Race Valve
    By S3DBW in forum General Technical / How To
    Last Post: 22nd July 2003, 12:29
