Chris NottMonster Motorsport
Results 1 to 12 of 12
    Jun 2012
    W.MIDLANDS
    7
    2003 1.8 T WHIRRING NOISE
    Just bought AUDI A4 03 PLATE 1.8T,6 SPEED,190 BHP which has developed this whirring noise which gets louder when speed is increased. The sound appears to be coming from below passenger side seat and when clutch is down and gearbox is dis-engaged the sound is still present.I've been told it could be the gearbox whine and not the wheel bearing which i suspected!!! So far i've done the service (oil/filters/plugs/coolant),had the cam/alternator belt changed,new tyres fitted.Yesterday i had gearbox oil checked and level was ok.What next???
    I WOULD VERY MUCH APPRECIATE ANY ADVICE FROM FORUM COMMUNITY
    cjsuk's Avatar
    Feb 2012
    Leeds
    554
    I would think wheel bearing, unless a wheel is catching somewhere due to dodgy springs/shocks, drive shaft bearings? Does the tone change when not in gear etc or is it literally a speed dependant noise?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,622
    if it's still noisy at stand-still it sounds like it'll be the Gearbox final drive. If it only happens when moving it's probably a bearing somewhere.
    2009 A3 SB 2.0T DSG S line
    Jun 2012
    W.MIDLANDS
    7
    Quote Originally Posted by Artimus View Post
    There is no noise at stand-still at all, whirring noise only starts to appear when speed goes over 30mph and starts to get louder as speed is increased.i'll eliminate wheel bearings first,thanks!!
    Jun 2012
    W.MIDLANDS
    7
    Quote Originally Posted by cjsuk View Post
    No the tone don't change in gear or neutral above 30mph roughly and is speed dependant ! I drove the car today on motorway and run a little test by dis-engaging the gearbox and turning engine off just to eliminate engine noise.The same whirring sound was still there.Also there wasn't any wheel play when I had it checked by mechanic the other day. Wouldn't drive shaft bearings produce more of a knocking sound?
    Jun 2012
    W.MIDLANDS
    7
    <br><br>
    No the tone don't change in gear or neutral above 30mph roughly and is speed dependant ! I drove the car today on motorway and &nbsp;run a little test by dis-engaging the gearbox and turning engine off just to eliminate engine noise.The same whirring sound was still there.Also there wasn't any wheel play when I had it checked by mechanic the other day.&nbsp;Wouldn't drive shaft bearings produce more of a knocking sound?
    simon.m's Avatar
    Oct 2009
    2,746
    stupid as this may sound have a look at the Tyre i had a whining sound and thought it was a bearing put the wheel on the back and the sound is now coming from the back not the front any more just a though
    Jun 2012
    W.MIDLANDS
    7
    I went for an easy fix straight away and replaced the old tyres which were on last legs as soon as the noise started.Now running on Continentals super contact 3 (245x45x17)
    cjsuk's Avatar
    Feb 2012
    Leeds
    554
    True tyres can make a racket too
    simon.m's Avatar
    Oct 2009
    2,746
    worth a shot ;-)
    Aug 2010
    1,540
    does the noise change if you swerve left to right and back again ie, loading the bearings up in different ways? if its a wheel bearing 9 times out of ten you can get the noise to change (louder or note change) when turning one way or the other.
    if the noise is constant its more likely to be in the gearbox.
    we had a fwd b6 130tdi in a couple of weeks ago.suspect wheel bearing, turned out the diff bearings were shot, there was actual side to side movement in the drive flanges!
    Jun 2012
    W.MIDLANDS
    7
    Just a feedback guys,had a wheel bearings checked out by different vw/audi specialist garage and everything was fine.It was pointed out that actual noise is bearings failing inside the gearbox which according to them is very unusual for petrol engine.I was quoted 900 pounds for re-build by gearbox specialist and after few phone calls managed to find a decent second hand gearbox locally (in a very good condition) with 6 months warranty for 450 cash.Fitting is going to be done this week,so i guess i'll feedback again.Thank you all for your response,cheerio
  1. strange whirring noise when shut down
    By mikeya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th May 2009, 10:23
  2. strange whirring noise coming from drivers side front wheel
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th March 2007, 23:37
  3. whirring noise at 60mph
    By JB_A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2007, 10:59
  4. Whirring noise from Aircon
    By MisterD in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th May 2005, 23:55
  5. Whirring noise
    By A4Steve in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2003, 12:32
