Volks AutosJMB Retrofits
Results 1 to 7 of 7
    imported_Smudge973
    Noise from the Gearbox !!!
    Driving home tonight there is a grinding noise when selecting 1 to 2nd and 3rd to 2nd etc - What could this be, any ideas ? ? It's never been there until now - Please help !!! Argh !!
    imported_Smudge973
    Re: Noise from the Gearbox !!!
    Anyone - Please reply - It's like I havn't engaged the clutch properly - only in 1st and 2nd ? ?
    mikeA2B's Avatar
    Aug 2004
    NW UK
    385
    whats the mileage on your car smudge? sounds like a worn gear selector / layshaft problem with the gearbox at worst or maybe clutch bearing? or possibly just needs fresh oil.
    Is it hard to select the gears?
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    is it cold when doing this ?
    imported_Smudge973
    The car has done 37k and is 9K from a service - Yes it is much worse when cold and clunky when selecting gear. But still bad when warm - Eg If you take it upto 5000rpm in 1st when you go into 2nd you can hear it crunch - at low revs it not such a problem. Why only these gears ? It's at the stealers on Thursday but I guarantee they will say "we can't find the fault" you watch - it's defo there. what do you reackon now ?
    The Slug's Avatar
    Nov 2004
    UK
    1,853
    what did they say?
    imported_Smudge973
