Air Con Belt change required on 2.5TDI Quattro
A3Kent
Hi chaps,
My mate at work has a B6 2.5TDI Quattro and says that the belt on the air con has snapped, in fact he's looked at it and it definately is broken and needs replacing. He was wondering if it was an easy fix?
He seems to think that you can remove the entire front of the car up to the side of the engine where all the belts are located including the air con belt and obviously the cam belt.
It would appear that the belt only drives the air con, is the correct?
Thanks for any help.
