AH FabricationsBadger5
Results 1 to 12 of 12
    May 2012
    12
    Coolant temperature gauge
    Hi all
    2002 B6 1.8t
    Hope someone can help, my coolant gauge is erratic, sometimes works and sometimes doesn't, always goes to 90 degrees when working though, I've replaced the coolant temp sensor with a genuine Audi one, and the heater works ok.
    I'm noticing that the radiator fans come on from a cold start in the morning and it has on occasion cranked a while before starting, could it be the thermostat?
    Thanks for any help given, am loving the car and just a few things to sort out (front pads, front and rear subframe bushes)
    Derek
    Andi25th's Avatar
    May 2010
    Inverness
    226
    If the fans are on it could be because your aircon is on. If its not on then possibly a faulty fan switch.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    id say its your temp sensor m8 easy and cheap fix....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    bowen's Avatar
    Mar 2011
    456
    if your fans are on in the morning when its cold etc it could be a fan switch. I have a fault temp gauge, the actual gauge can be at fault.
    Audi A4 B7 SE S line TFSI Quattro.
    May 2012
    12
    Cheers guys, good tips, I'll pick up a fan switch and yeah Bowen I suppose it could be the gauge, I'll check that out too, thanks again
    bowen's Avatar
    Mar 2011
    456
    i know mine is the gauge ia vagcom, however it was pretty obvious it was the gauge as it would sit at 90 with the engine off and other odd signs.
    Replace the temp sensor with a OEM part no cheap ebay ****. I actually think i have a spare OEM one, let me know if you want it.
    With the fans going, on and off at cold start I would imagine that the fan switch has had it. £440 iirc at the dealer?
    Jul 2007
    770
    Wont be the stat if the heaters OK and I would expect a switch to fail in the off position.Why not disconnect the switch and see if the fan stops?Seems like a faulty guage to me
    May 2012
    12
    Thanks guys, if you mean the coolant temp sensor Bowen then I've replaced it with a genuine one, so I had the car scanned today using vag-com and it's throwing up 17704 - error in mapped cooling system, check temp sensor and thermostat
    P1296 - 008 - implausible signal
    Any ideas what this might be?
    Ill also try the fan switch thing Mike B, thanks
    bowen's Avatar
    Mar 2011
    456
    the heaters are hot and stay hot? even stationary in traffic?
    May 2012
    12
    Good point, ill do a full test tomorrow to find out, I forgot to mention that the engine managment light is on also, I'll keep this updated
    Thanks Bowen
    May 2012
    12
    Heater is fine and hot even in stationary traffic, is it not the thermostat then?
    Cheers guys
    May 2012
    12
    Just an update, i read the codes again today with the engine on and the fan was running (from cold) and then cleared them, once i cleared the codes (DTC's) the fan stopped running (it will switch off anyway after a while) hmmm
    Also got this code from Vag-com today, could this mean my gauge is faulty?
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
  1. coolant temperature gauge not working.
    By fdt140876 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st March 2012, 00:16
  2. Fan, Temperature gauge and Coolant problem
    By D89 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th January 2012, 13:07
  3. Temperature gauge on an Audi80 2.0e 1994
    By yorky068 in forum Classic Audi Forum
    Last Post: 14th July 2006, 00:47
  4. Temperature gauge warning light on cold start
    By imported_monkeytrousers in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th December 2004, 18:18
  5. trouble code coolant temperature below normal?
    By dann959 in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th September 2004, 05:36
