EM TuningJMB Retrofits
    Feb 2012
    20
    HELP!!! error codes, cars shaking whens the engine is on.
    hi iv got audi a4 b6 1.8T
    whens the engine is on it goes on 800rpm exaust sound changes, sound like its spiting something out and all car starts to shake and the engine light starts to flash.
    o get these erro codes
    17705 pressure drop between turbo and throttle valve
    (check D.V.!) P1297
    16684 Random multiple cylinder misfire detected: P0300
    16688 cylinder 4 misfire detected: P0304
    16686 2 : P0302
    16687 3 P0303
    16685 1 P0301
    17701 map controlled engine cooling thermostat (F265):
    short to plus: P1293 - static - value of resistance too small
    thanks for your help!!!
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    start with checking coil packs check if yours is due a recall from stealers, also scrap the plastic dump valve and buy forge 007
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Feb 2012
    20
    Quote Originally Posted by marktdisport View Post
    yh gonna get change all coils on sunday. let u all know if problem got solved.
  1. A3 Car shaking when stationary
    By iamwhatiammomo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2012, 23:58
  2. Help! Error when uploading the original chip setting to Bluefin
    By kinson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2010, 10:31
  3. Strange squeal when the engines not under load
    By Nutkin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th March 2010, 02:26
  4. got my car back after the engine reconditioning
    By mrjheeta in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2008, 18:31
  5. Car shaking when idling
    By Burt25 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th June 2006, 10:39
