Chris NottVolks Autos
Like Tree1Likes
  • 1 Post By NickRB
Thread: Audi A4 Convertible/Cabriolet roof problem and possible solution
    Jun 2012
    Hi,
    I recently had a problem with the roof slowing down and eventually stopping on my A4 Convertible. I consulted the forum and came across an excellent article from Krumz in relation to cleaning the hood motor. Link to the article as below:
    Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
    I followed this article and did exactly as described but unfortunately this did not cure the problem. In the article was a link to a chap on Ebay who rebuilds motors so I got in touch with him as he was fairly local to me. Link below:
    Audi A4 Cabriolet Roof Motor Repair (Power-Packer) | eBay
    In short while the A4 was in to the local main Audi dealer (York) for a cambelt change I asked them to diagnose the hood fault and was told I needed a new pump which would be £1200 plus!
    When speaking to Mervyn (Ebay chap) I described the symptoms of the hood not working and he immediately confirmed it was a motor fault as the original brushes fitted to the motor are of poor quality. He also advised that rarely do the pumps fail and that he had reconditioned hundreds of motors.
    I visited Mervyn and within half an hour he had cleaned the bushes up and confirmed the motor was working fine. This did the trick but the hood still struggled which was down to the pump not having enough hydraulic oil in the reservoir. Topped up the oil and the hood now works perfectly.
    The article from Krumz was spot on and very comprehensive. Mervyn is very helpful and his contact number is in the link. He does a very quick mail order service for your motor as described in the link.
    Overall this solution cost me £30 for Mervyn to clean the motor (I had already removed the trim to gain access) and £8 for a bottle of hydraulic fluid from Audi. Total £38 as opposed to £1200 plus from Audi!!!
    Do not have faith in main dealers, they mis-timed the new cam belt when fitted and the car had to go back to be set up properly and on a health check they completely misssed a tyre that was illegal on the inside despite them stating it had 5mm!
    Hope this post helps as the links saved me a fortune.
    Thanks again to the forum, Krumz and Mervyn
    Nick
    JLBmatic likes this.
    bowen's Avatar
    Mar 2011
    456
    Thanks for this, very useful!
    Audi A4 B7 SE S line TFSI Quattro.
    Mar 2009
    449
    Very useful info indeed. Many Thanks and good to hear of a nice result. Any pics of your cab?
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Jul 2012
    17
    Brilliant brilliant brilliant!
    Aug 2013
    Motor fault
    Thanks for this. I had a similar fault, removed the pump motor and sent it off to Mervyn at Autoelectron (very helpful over the phone as well), received it back a couple of days later and happy to say all working fine now.
    So, thanks for this post, thanks to Mervyn and hope this helps anyone else.
    If you think you may have the similar fault, check out:J
  1. Audi A4 2007 Cabriolet - roof problems... help please!
    By jordan_audi_2012 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th March 2014, 13:34
  2. Replies: 1
    Last Post: 19th June 2012, 15:55
  3. 1996 Audi 80 Cabriolet - Roof Problems
    By stellarborne in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:30
  4. Cabriolet Roof Problem - Please Help!
    By StuartC in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:22
  5. Audi Cabriolet roof problem
    By RoStar in forum Classic Audi Forum
    Last Post: 28th March 2004, 18:47
