Volks AutosEM Tuning
Results 1 to 10 of 10
    Jun 2012
    durham
    engine tappety when starting up from cold
    I guess this subject has been covered many times, I'm new to the forum so can only apologise for going over old ground.
    Question is - my 1.8T petrol is starting to become tappety when starting from cold, could this be down to not having long life oil in system or do I need heavier grade oil or is the problem something more sinister ???
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    14,289
    Welcome to ASN. Any pics of the car? Have a read in the faqs threads at top of the page. Lots of info in there. Enjoy the forum. x
    Smaller (Local) Events
    Audi-Sport.net online magazine.
    To find Audi-Sport-Net members with VCDS check out the MAP.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    sounds like the oil pick up pipe is caked up in sludge... lack of oil changes and incorrect spec oil id say
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Aug 2010
    1,540
    first off id get the oil pressure checked by a separate guage.
    if its correct it might just be a couple of sticking/knackard tappets.
    try running a good engine oil flush thru it and changing the oil.
    Lancaster
    1,624
    Personally if it was me, i'd be tempted to take the sump off, give it a clean out. Take off the pickup pipe. Clean that out.Put in some longlife genuine audi oil and change it again in 5k.That's just what I'd do though.Genuine oil should give it a good clean out without releasing any possibly sludge too quickly.
    To do: None yet.
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Would these solutions be the same for a diesel?
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    Lancaster
    1,624
    Quote Originally Posted by scottshere View Post
    Yep, diesels are diiiiiirty if not serviced correctly.
    To do: None yet.
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    Do you remove the pil pickup pipe after taking the sump off ?
    (Noob question)
    Leaky Lloyd's Avatar
    Apr 2010
    280
    FIRSTLY ID JUST LIKE TO SAY I FEEL YOUR PAIN BROTHER,,
    AND I AM IN NO WAY SAYING THE OTHER GUYS ARE WRONG BECAUSE THE TRUTH IS ALL OUR OPINIONS ARE 2ND GUESS AT BEST,
    BUT BEFORE YOU TRY SOME OF THE MORE INTRICATE SOLUTIONS, TRY THIS,,
    IVE HAD THIS VERY SAME PROBLEM RECENTLY,, BUT ONLY WHEN COLD, IT DROVE ME CRACKERS FOR MONTHS !!!!!
    IT TURNED OUT TO BE THE AIRCONDITIONING PULLY THAT WAS SHAGGED,,,
    THE LUMPYNESS OF A COLD START IS ENOUGH TO MAGNIFY THE RATTLE,
    YOU CAN ALSO ACTUALLY MAKE THE CAR RATTLE IF YOU PUT IT IN GEAR, WITH HANDBREAK ON AND SLOWLY DIP THE CLUTCH TO PUT THE ENGINE UNDER STRAIN,, THIS WILL REALLY MAGNIFY IT
    ME AND MY MATE WHO IS ALSO MY MECHANIC SUSSED IT OUT,
    IF YOU ARE CONFIDENT ENOUGH, AND BEFORE YOU 1ST START YOUR CAR, PULL THE BELT OFF AND RUN FOR A MINUTE OR SO, BUT NO LONGER !
    IF YOU DONT HEAR THE SOUND YOUR HALF WAY THERE,,,
    NEXT,, ROTATE THE AIR CON PULLY IN A QUICK MOTION CLOCK WISE AND ANTY CLOCKWISE, ALMOST AS IF YOUR SHAKING IT AND ALSO RATTLE IT ON ITS AXIS,,
    IM PRETTY CONFIDENT YOUR GUNNA HEAR THAT NOISE THATS BEEN DRIVING YOU CRACKERS COMING FROM IT !!!
    AIR CON PULLEYS ARENT TOO EXPENSIVE EITHER AND APPARENTLY IT IS A COMMON PROBLEM
    I WAS OVER THE MOON WHEN WE FINALLY GOT TO THE BOTTOM OF IT, MINE RUNS SWEET AS A NUT NOW
    GOOD LUCK WITH IT MUCKA,, LET US KNOW HOW YOU GET ON !
    Apr 2011
    160
    Mine did just that it was the cam chain tensioner rattling. I thought is was on its way out, about 2 months later oil pressure light came on. So dropped sump, sorted the pick up pipe. Noise gone and engine is a lot smoother at idle now too. So as mentioned above I'd get oil pressure checked.
  1. S3 pop noise on start up from cold
    By scotty_24 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th July 2012, 19:48
  2. An intermitant rattle or tapping on start up from cold.
    By funnyclub in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st November 2010, 17:53
  3. Noisy start-up from cold start???
    By linners in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2010, 15:47
  4. S4 V8 engine rattle when starting only
    By Boomerations in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 5th October 2009, 22:05
  5. High pitched noise when starting from cold
    By ajek in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th November 2004, 15:00
