EM TuningJMB Retrofits
Results 1 to 12 of 12
    Sep 2005
    Staffordshire, UK
    455
    Clattering Noise!
    Hi guys,
    If you read one of my other posts a while back I was having a clattering/banging noise on start up from my Audi A4 1.9tdi 2004 Quattro....Only happened occasionally on start up and slowly its got worse.
    It now happens really when in gear, under very low revs and low speed.....The noise a loud clattering/tapping/banging noise....
    I have a suspicion this is probably the DMF, but how would it make such a noise?
    Any ideas for this?
    Cheers, I know it's a long shot!
    Rich
    Audi Avant A4 54 1.9Tdi Quattro & Leon Cupra R 2005 1.8T remapped to 275bhp
    Sep 2005
    Staffordshire, UK
    455
    Any ideas peeps?
    boost-addict's Avatar
    Aug 2011
    977
    possilbe has it had the correct oil changes etc does it sound like the bottom end going, unlikley but just go single mass if it is the dmf
    Sep 2005
    Staffordshire, UK
    455
    Quote Originally Posted by boost-addict View Post
    Hmmmmmmmmm yeah has had oil changes fine and had all the top end checked fully for camshaft wear and all that!
    Apr 2011
    Ross-on-Wye
    26
    Its possible that it could be pas pump .... or AC pump but possibly more than likely its your oap there really common for going.
    Regards
    Leaky Lloyd's Avatar
    Apr 2010
    290
    ive had a similar problem and posted in other threads of similar discriptions and my problem is now 100% solved !
    it turned out to be the air conditioning pulley
    heres what you need to do to test it,
    start the car for maybe 30 seconds just to check the noise is there but dont let it warm up !
    then,remove the belt which goes around all the pulley's at the front of the car (christ knows what its called im not a mechanic)
    start the car (BUT ONLY FOR A COUPLE OF MINUTES!!!!!!), if the noise is gone then your half way there
    now, the air-con pulley if i remember correctly is (as you stand infront of your car) the one to the right hand side right down at the botttom.
    with the engine off,, rotate this wheel by hand bock clockwise and anty clockwise say 5mm in each direction as fast as you can, and also try rattling it on its axis ?
    as soon as we did this we knew we had the problem nailed,
    changed the pulley, slipped the belt back on and bobs your mothers brother,,,, problem solved !
    good luck with it matey !
    Sep 2005
    Staffordshire, UK
    455
    Ive had the common alternator pulley changed when I had the car 2 years ago in Nov....can't see it being that again..... is that the same thing????
    Is this the air con one different presumably do?
    Its making the noise on Idle as well, just clatters quite regularly when idling! Annoying!
    Apr 2010
    290
    same sort of problem,, different pulley !
    Sep 2005
    Staffordshire, UK
    455
    Guess what, it's the Air Con Compressor Clutch! Great £430 fitted!
    Aug 2011
    977
    at least it wasnt any thing to do with the mechanical side of things (engine wise) so at least its a straight forward job
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    pm leaky lloyd m8 as he fixed his for cheap im sure it was only around £30 quid fix to reasemble the clutch and this would save the expensive new compressor
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Sep 2005
    Staffordshire, UK
    455
    Thanks mate, have PM'ed him but no reply.
    Rich
  1. A3 2l TDi on last legs clattering noise when cold, owl turbo etc
    By Matt_Storm in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2012, 22:10
  2. Clattering noise & vibration 2.5 V6
    By Tankman in forum Diesel forum
    Last Post: 24th August 2009, 21:11
  3. 16valve horrible clattering noise , whats the cause ?
    By MHage in forum Classic Audi Forum
    Last Post: 29th November 2005, 16:31
  4. Cold Startup Noise
    By mramage in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd January 2003, 21:52
  5. Phat noise unit?
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 18:33
