Monster MotorsportVolks Autos
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Question changing a power steering pump
    on my B6 2.5TDI
    to change the power steering pump, is it a front off job or is it a from below job, Easy ?
    Thanks in advance...
    beachbuggy's Avatar
    Surrey
    1,744
    Enough room under to get it out, fiddly but can be done
    Lancaster
    1,780
    From under? On a 2.5? Jesus. I certainly couldn't do it!
    Turkster. I took the front end off mine and just moved the panel out a touch. It's hard enough as it is to get things like the fan off.
    To do: None yet.
    Turkster's Avatar
    Dec 2007
    2,723
    Quote Originally Posted by BlackQuat View Post
    yep, its tight, may give it to the lads to do, my one is squealing like a ***** on full lock now, i've topped up the fluids and pumpped it, but its not getting any better and its got to be sorted soon,
    Aug 2010
    1,540
    naa front off.
    i dont see how you can get to the 17mm allen key on the aux belt tensioner, to get the tension off the belt, without taking the viscous off and undoing the 3 6mm allen keys out of the front cover to remove the cover itself.
    Jul 2007
    London
    3,235
    I would also check the aux. belt tensioner and bearings in the alternator, they known to fail with high mileage motors- also require front off to replace...
    FOR SALE:
  1. Power Steering Pump
    By ghost.s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2009, 11:17
  2. New power steering pump
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2008, 13:40
  3. Power steering pump recon or replace?
    By Beef in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2007, 09:07
  4. Alternater power steering pump belt probs
    By silveravant in forum Diesel forum
    Last Post: 22nd October 2006, 22:20
  5. Noisy Power Steering Pump
    By madkebab in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2004, 12:21
