Chris NottVolks Autos
Results 1 to 7 of 7
    A4 TC's Avatar
    1.8T quattro sline
    Nov 2006
    Toon Toon
    194
    EML keeps coming back on ! Help please !
    Hi guys need help badly !
    Had the EML come on and reset on numerous occasions and had it scanned and the code come up with P1128 and other codes saying running lean , quick search on this forum and suggestions are change the maf and airflow sensors !
    These have been changed today leaks have been checked for ! And driving home today the EML has come back on again ! Starting to really p*ss me off now cause its been back to the garage numerous times .
    So guys , is there anything else I need to check or change to get it back to normal again ?
    Cheers A4 TC
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,691
    After you changed those things was the car rescanned for fault codes? And had they gone?
    A4 TC's Avatar
    1.8T quattro sline
    Nov 2006
    Toon Toon
    194
    The car was rescanned and the p1128 fault code cleared ! The car drives fine for a little while , then I can tell the engine management light is going to come back on cause the car struggles for power and feels very flat ! and another visit to get it scanned again , the same problem of running lean ! Getting sick and tired of back and forth to garage !
    P.s it's a 1.8t Quattro sline by the way !
    May 2012
    Norfolk
    118
    It may be worth pressure testing the boost system and checking all the vac lines my mate had similar and turned out to be a broken nipple on the inlet manifold that the fuel pressure regulator connected to
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Needs logs done ideally. But a lambda sensor can go bad and cause it without a code being thrown...
    A4 TC's Avatar
    1.8T quattro sline
    Nov 2006
    Toon Toon
    194
    Finally ! Hope this sorts it ! A split has been found on the air intake pipe right where the jubilee clip is , so made it harder to find !
    Thank you guys for the input given !
    May 2012
    Norfolk
    118
    Quote Originally Posted by A4 TC View Post
    Glad your have hopefully sorted it mate
  1. Back brake help please
    By s3gazz in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2012, 21:52
  2. abs light and esp light keeps coming on help please
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th December 2010, 19:50
  3. Air bag light decided to come on ? Help please
    By fozworth in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th September 2010, 22:33
  4. Back speakers keep coming on and off
    By boson in forum In-Car Entertainment
    Last Post: 3rd June 2009, 17:42
  5. Replies: 3
    Last Post: 13th June 2005, 23:49
