Monster MotorsportEM Tuning
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,108
    Vibration through clutch pedal
    Hi Peeps..... my lad brought his A41.9 TDi round tonight with a problem.... when you drive along and take your foot off the gas and lightly rest your foot on the clutch pedal you can feel a vibration... if you accelerate the vibration goes away at first i thought clutch release bearing but it makes no noise when you depress the clutch and it dosn't do it when stationary so then i started thinking dual mass flywheel but i was led to beleive when these start to fail they make a ratling noise when ticking over which this dosn't so now i'm inclined to think it maybe gearbox internals.... has anyone come across a similar problem ??? i don't really want to start stripping all down just yet as it's not a major vibration but there's certainly something amiss
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    bowen's Avatar
    Mar 2011
    456
    When the pedal is fully pressed in does the vibration go away?
    Audi A4 B7 SE S line TFSI Quattro.
    Mar 2008
    Oldham, Manchester
    1,108
    Yes i think it did.....only does it whilst your moving though which is why i'm thinking it's not the flywheel because that would do it all the time wouldn't it ?
  1. Replies: 21
    Last Post: 6th January 2011, 19:30
  2. How does your A4 drive - vibration through accelerator pedal?
    By PATCH in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2009, 18:12
  3. Vibration through clutch pedal
    By grey99 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2006, 22:42
  4. clutch pedal vibrating
    By imported_kris_tdi in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th September 2004, 21:12
  5. 1.9 TDI Serious Clutch Pedal Vibration
    By matt_splatt in forum General Technical / How To
    Last Post: 13th April 2004, 22:53
