JMB RetrofitsEM Tuning
    Jun 2012
    Johannesburg, South Africa
    12
    Audi B6 A4 1.8T BEX Misfire Under Load
    Hi all
    I am having a strange issue with my A4 where under heavy load such as full throttle in 3d or 4th gear from around 2000 rpm she will start to cut out/splutter at around 3000 rpm and feels like a misfire. It is strange because if I run her on her normal stock map I cannot replicate the misfire but as soon as I run even a basic Stage 1 REVO map she misfires. Obvious causes are plugs, coil packs, leads or injectors but what gets me is she runs fine on her stock map...
    Any thoughts? I have yet to run logs on her so that will be my first port of call...
    Nic
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,160
    Definitely sounds like coil-packs - my Ibiza 1.8T did the same.
    I got a set of four Beru (OEM quality) from eurocarparts - cost £115 for the four if I remember correctly.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Jun 2012
    12
    Quote Originally Posted by AlexGSi2000 View Post
    Thanks for the feedback, I know these and other 1.8T engines suffer from coilpack favour but I was led to believe that the coilpacks were replaced by my local Audi before I bought the car. Will be doing some logging and testing this weekend with a friend who has the same car...
    Nic
    Current Garage:
    Daily Drive: 2005 Audi B6 A4 1.8T Avant S-Line
    Project Fes: 1982 Golf GLS 1.5
    Project FeO: 1966 Type 2 Transporter Kombi Split Window
    Project XXXX: 1967 Volkswagen Type 3 Variant (Squareback)
    Previous Garage:
    Project Betty: 2005 Polo 1.9 TDI Sportline
    Weekend Warrior: 1993 Volkswagen Caddy 2.0 16v ABF on ITB's
    pauldazzle's Avatar
    Cardiff
    639
    There's a recall for coilpacks so call you local Audi dealer to see if it applies to your car. Worth checking the MAF as well as I experienced problems with a GSF MAF on a Revo'd mkiv Golf once. Stuck a genuine VAG MAF on & all was well.
    A4 Avant B6 1.9 TDI 130 Sport (6) Moro Pearl Blue, GMBH S Line Kit, Decat, 165bhp remap, EGR delete, K&N panel, Dunlop SP Sport Max, Full Leather, Cruise Control, Full DIS, Bose, Audi phone prep, Cooled Glove Box, Rear privacy glass, Rear parking assist.
    2003 Seat Ibiza 1.2 TSI FR in Lima green.
    Jun 2012
    12
    Quote Originally Posted by pauldazzle View Post
    The car is going to my local Audi dealership on Wednesday and I'll get them to check if the coilpack recall was done. I did ask at the last service but I don't trust dealerships to be completely honest. Switched back to the stock map this last weekend using my REVO SPS and loading her with full throttle from 2000rpm in 4th there is no misfire at all. Seems like the added boost/fuelling is exposing a weak link...
    Nic
    Current Garage:
    Previous Garage:
  1. A4 1.9 TDI pd 130 misfire - cough/mis/splutter under load - judder on idle
    By ian-r in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2012, 20:09
  2. Allroad 2.5 TDI Misfire/Judder Under Load
    By tekno_al in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 2nd August 2012, 22:56
  3. Bad misfire under boost
    By Welly in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd December 2009, 22:45
  4. Help please, Audi A3 2000, 1.8t apparently misfireing
    By mobymaster in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2007, 21:34
