Chris NottMonster Motorsport
Results 1 to 17 of 17
    hitman1978's Avatar
    Apr 2012
    castleford
    106
    1.8t 190 fluctuating boost
    Hi, I've recently had revo stage 1 installed and the boost seems to be fluctuating, it peaks around 22psi but bounces around between 15 psi and 18 psi, anyone any ideas as what could be causing this?
    boost-addict's Avatar
    Aug 2011
    977
    not sure, best ringing revo and or go back to them.
    but could be some thing simple as a n75 but then could be a fault in the map.
    they tuned it so its best to get it sorted by them.
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,303
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    N75 or Maf, could also be boost leak, id check in this order too
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    hitman1978's Avatar
    Apr 2012
    castleford
    106
    This might sound really dumb, what and where is the n75 valve?
    Aug 2009
    north east U.K
    1,303
    its on the turbo intake pipe off the top of my head, little black plastic thing around near the maf area
    hitman1978's Avatar
    Apr 2012
    castleford
    106
    Do you mean the recirculating valve?
    Aug 2009
    north east U.K
    1,303
    no mate smaller than that, its square
    hitman1978's Avatar
    Apr 2012
    castleford
    106
    I'm absolutely clueless with these engines, is it going to be a main dealer part or is there anywhere you'd recommend to get parts from?
    beachbuggy's Avatar
    Surrey
    1,742
    Quote Originally Posted by hitman1978 View Post
    Assume you have a boost gauge to view this?
    Boost is load dependant and also temperature. You may just find its the way it's mapped or the way you drive! Only real way to test is to run a WOT run from 2k to redline in 3rd and see what you get, any other way is near pointless to measure.
    hitman1978's Avatar
    Apr 2012
    castleford
    106
    I'm definitely dumb now, what's a wot run?
    Aug 2011
    977
    Wide Open Throttle
    basicly full throttle
    do you have a boost gauge? get a vid from 2k 3rd gear to read line. full throttle
    hitman1978's Avatar
    Apr 2012
    castleford
    106
    Yes I have a boost gauge, I'll get a vid tomoro and try and post it up
    hitman1978's Avatar
    Apr 2012
    castleford
    106
    I've managed to get a vid and uploaded to YouTube, but damn thing won't display the url, my post is a4 1.8t revo stage 1
    beachbuggy's Avatar
    Surrey
    1,742
    Ok, think I've seen your vid. I'd say almost certainly it's just the way it's mapped. Peaking at 22psi is normal for Revo! Very spikey as they over shoot the requested boost, then the n75 tries to regain control of the boost and by nature fluctuates which is the variable boost you see before it stabilises and drops. The n75 in affect oscillates the boost until the required level is met, the bigger the variation ie over shoot the more it needs to oscillate to regain control. A sensible map will have less over shoot thus the oscillation are more stable and the boost fluctuates less or not at all.
    Revo are spikey which results in what you see. Nothing wrong with it just a different way of tuning.
    hitman1978's Avatar
    Apr 2012
    castleford
    106
    Thanks for the reply, it seems its sorted now aswell, doesn't over boost anywhere near as bad now I've refitted the larger pipe from intercooler to throttle body? I noticed it had managed to make its way about 10mm down the flange it connects to, don't suppose you know anywhere that sells aftermarket ones, mines rather soft, cheers
    beachbuggy's Avatar
    Surrey
    1,742
    Forge is the only company I know that sells aftermarket boost pipes.
    hitman1978's Avatar
    Apr 2012
    castleford
    106
    I've been looking on there site, think I've found the right tip, with the 5 connections on it, but can't find anything listed for the pipe I'm after
    A4 b6 1.8t 190 sport Quattro avant revo stage 1
  1. Boost fluctuation now car is chipped. Any ideas?
    By B5QUAT in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd November 2011, 14:33
  2. BEX engined A4 190 1.8t boost problems (dealer has confused me!!!)
    By thetroublemaker in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2011, 15:36
  3. boost fluctuation at low revs (p1200) boost control valve fault code
    By 4rings in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2011, 07:28
  4. Boost Fluctuating
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2010, 18:24
  5. Standard Boost - A4 1.8T 190 Bhp
    By tbcuprat in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th October 2006, 13:48
