Volks AutosSky Insurance
Thread: fuel pump noise
    Apr 2011
    160
    fuel pump noise
    Ok I have a strange noise, thinking its a fuel pump. Sounds like its picking up air. I'm assuming that it has two pumps one to feed the engine pressure and one to balance both sides of the tank. No change in performance. It's intermittent. So at the moment I'm thinking it could be the second pump on all the time when I shouldn't be( if there is one).
    Any ideas, 2001 1.8t AVJ(so no fuel return) quattro.
    Apr 2011
    160
    So does anyone know if there is two pumps.
    Apr 2011
    160
    Ok so only one pump. Opened the tank up. There is air bubbles coming out of the relief valve. So getting air from somewhere. The other side of the tank is pretty dry, so I guess its getting air from that side.
    Anybody aware of how the system works. Regarding how it draws fuel from the other side of the tank.
  1. 2010 Allroad 3.oltr fuel pump noise after software upgrade
    By dminty in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 27th April 2012, 18:58
  2. Underfueling and noise from the fuel pump
    By spiker in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th June 2010, 14:58
  3. best place to buy a late coupe fuel pump
    By lazzaman in forum Classic Audi Forum
    Last Post: 25th November 2006, 21:48
  4. Fuel pump problems
    By nunzio42 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2005, 12:09
  5. Fuel Pump Noise
    By europabluea6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th September 2003, 18:15
