AH FabricationsSky Insurance
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    1.9TDI Multitronic won't start after accident
    Hi,
    I have just helped a friend bring home a 2004 A4 1.9TDI multitronic, it was involved in an accident, he bought it bent, had it repaired and have just realised it is refusing to start.
    The ignitition switches on fine, DIS says press footbrake to start but no gear position shown in the bottom section (can't remember if it should on not at that point)
    Odd thing is that with the key off the gear selector is locked in park, but as soon as the key is turned it is free to move to any position (without the brake pedal pushed) which isn't right.
    I have scanned the car for codes, the engine showed
    18034 - Powertrain Data Bus: Missing Message from TCU
    the ABS showed,
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    18055 - Check Coding of ECUs on Powertrain Data Bus
    18034 again
    I could not connect to the transmission.
    Apparently the damage to the car was around the base of the A pillar on the drivers side behind which there is various electrical components so speculation is that something has been damaged in there.
    Any ideas what to look for?? Help gratefully recieved
    2001 A4 Avant SE 1.9TDi
    mattpanton's Avatar
    Sep 2005
    Suffolk, UK
    123
    Anyone??
    I should add that it won't crank, just as if the gearbox inhibitor is working all the time.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,159
    Is the car cranking over with the key?
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
  1. 1.9tdi ahu won't start help!
    By stevojam in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th May 2012, 08:13
  2. Bike won't start after using NOS **Epic thread**
    By andyb_88 in forum General Chat
    Last Post: 30th January 2012, 23:19
  3. Car won't start after taking out the instrument CLUSTER HELP!!!!
    By Gsai in forum VCDS (formerly VAG-COM) forum
    Last Post: 27th March 2011, 18:48
  4. Car won't start in morning!!
    By JayA4Turbo in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th October 2003, 23:25
  5. Won't start!!
    By ray_nsm in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2003, 00:25
