JMB RetrofitsEM Tuning
    Jul 2004
    Bridgend, South Wales
    47
    Unhappy Steering rack gone..
    Hey guys,
    Last night the car emptied its power steering fluid out through the drivers track rod gator all over the road, so it's safe to assume i need a new rack. It's a 2.5 TDI quattro and i'm trying to find out whether the part number would be the same for other b6 a4's or not? Can i fit an avant steering rack for example? can i fit a non quattro rack? is there any difference?
    Any help would me much appreciated.
    Mar 2008
    1,058
    look on etka see if there is any other part numpers
    Oct 2009
    Hull
    1,442
    I think they and all the same but I will check on etka when I get chance
    I even think the passat one is the same
    Lancaster
    1,787
    Do a search on ebay for cardif audi. I got a B7 rack from them for just over a £100. Brand new genuine audi. Also got 2 litres of genuine fluid too.
    It's actually not a hard job either bud. I recently did mine.
    To do: None yet.
    Jul 2004
    47
    Cheers guys, I've ordered a rack now so just trying to remove the old one. Has anyone done this on a v6 block? If so any pointers on removing the heat shield? I just can't get to the two screws at the top.
    Lancaster
    1,787
    Yep I have bud.
    The bolt on the passenger side. You can just bend the heat sheild out of the way enough.
    Drivers side. There is a 8mm screw into the body. Which when you take it off, lets you pull the heat sheild out of the way enough to do the job.
    To get the rack out of the car. Undo the top mount from the strut top. Drop it down abit and pull forwards. This will allow you to pull the rack out of the drivers side.
    To do: None yet.
  1. Dreaded steering rack gone on my 2.5 V6 Quattro...help?
    By jonnycraig in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th November 2009, 09:23
  2. Possible Leaking Steering Rack A4 2.6 Quattro
    By RICHARDJC in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2005, 11:40
  3. steering rack removal
    By zirconium in forum Classic Audi Forum
    Last Post: 8th September 2004, 09:09
  4. Steering rack problem
    By mramage in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th June 2004, 08:51
  5. Steering rack
    By GolfV5 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd March 2004, 23:27
