EM TuningSky Insurance
Results 1 to 18 of 18
    May 2012
    12
    AUDI A4 1.8T 190BHP acceleration problem car judering when foot fully down
    looking for some help.
    I just brought a 2003 audi a4 1.8T (190BHP) it has the BEX engine 6 speed.
    It has about 60k on the clock, i just gave it a service, new oil, oil filter, air filter, spark plugs, new cambelt kit and waterpump. i even changed the MAS air flow sensor.
    It also had a new coilpack before i brought the car from audi on a recall free of charge service. it has paper work to proove this and also we checked the coil pack and it looks new.
    the problem was there before i got it serviced aswell as after, but when i accelerate with foot fully down the car judders back and fourth when it picks up speed, its a bit hard to describe but it feels like it accerlates stops and accerlates again whilist picking up speed, its more noticeable in 5th and 6th gear. it doesnt happen when you accerlate gradually. any ideas what this could be and has this happend to any one on here?
    any help or ides what could be the cause would be highly aprecated.
    thanks in advance.
    jazz virdee
    Oct 2009
    Hull
    1,442
    You ideally need to get it scanned for fault codes
    But I'm sure people have had similar problems when the map sensor was dodgy
    May 2012
    12
    hi, i got it check on vag, but not fault codes came up, i will check out the map sensor. hopefully that will do the trick. its become a bit annoying.
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    232
    I'd say its the Dual Mass Flywheel or Clutch
    Has the car been remapped? Does it only do it from low revs in the high gears?
    Audi A4 1.8T S-Line Quattro (190) '04
    VCDS HEX-USB+CAN
    May 2012
    12
    hi, i dont think its been remapped, its all standard, i just brought the car a month ago, i didnt notice it on test run.
    it only happens when i put my foot down so in high revs.
    May 2012
    12
    it would happen in most gears even when im reaching over 100mph... i have a manual gearbox with 6 gears
    beachbuggy's Avatar
    Surrey
    1,746
    I'd suggest if it's happening at WOT then it could be running lean, an injector issue or you have a misfire from a bad spark plug or bad coil .
    May 2012
    12
    i think cheapest option wouldbe to change the map sensor first. the spark plugs where just changed 2 weeks ago. coil pack was changed by audi on a recall last month..
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    Either your clutch is on its way out or your n249 valve is not working properly.
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
    May 2012
    12
    the bighting point is a little high, but i cant get it to slip...
    May 2012
    78
    Not too sure why teh clutch is being mentioned? If it was slipping, it would be obvious!
    Its hard to say, as your description sounds like its quite a subtle loss/gain in power? Or is it quite aggressive?
    It may be worth getting a cheap boost gauge or live reading on what the boost is doing and see what the readings are under load - as it could be mechanical?
    beachbuggy's Avatar
    Surrey
    1,746
    You mention in the 2 posts and I quite "coil pack was changed by Audi" now was this just 1 coil pack or all 4? As they should have changed all of them but if just 1 was changed then one of the other 3 could have failed. I very much doubt the clutch is the issue. Get it scanned please, if you have say a faulty injector and it's running lean, which would cause a judder, and you continue to drive it you will melt a piston! And then you'll have major issues. Don't guess , get it sorted
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    just read this thread mate and having experienced a very similar problem a few months back, id definatly say coil pack. ring audi and make sure they change all of them, as beach buggy said they may have just changed the one.
    b
    ut 100% sounds like what i had at the begining of the year!!! prob best not keep driving it like this if it is!! dont wanna cause more damage
    Next Steps. (wanted)
    s`line steering wheel
    oem interior mods
    milltek exhaust system..
    window tints.
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    saying that. i just noticed you said about being in 5th gear. whn my coil pack had gone down, i couldnt get it higher than 2nd
    oem interior mods
    window tints.
    May 2012
    12
    i went to audi to see what was replaced and all 4 coils have been replaced before i brought the car. i have it booked in a local garage on monday, hopefully he can find the fault on his machine..
    May 2012
    12
    all 4 was changed in april 2012 and confirmed by audi. its booked in tommrow at a local gargae in wembley, hopefully they can find the fault,
    Quote Originally Posted by beachbuggy View Post
    May 2012
    12
    its subtle loss/gain, it feels like someone keeps pushing you from be behind while your walking... only way i can describe it...
    Quote Originally Posted by Willf View Post
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    it does sound like it's been remapped and it's not a smooth power delivery !! but if it's standard that rules that out....can you pipe a boost gauge up and take it for a test run and see what the boost levels do..... sounds more mechanical though possible weak actuator or possible the dodgy standard recirc valve... so id change that first with a 007 forge
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
  1. Weird Acceleration Problem
    By StokeTDi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th October 2007, 17:12
  2. Audi man now, but here are previous cars!
    By GFORCE in forum Other Brands & Models
    Last Post: 6th March 2007, 19:49
  3. Help! Immobiliser Problem - Car Won't Start
    By coajt in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2007, 18:06
  4. Audi A4 1996 TDI 1st gear problem :( Help !!!!!
    By slips in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th October 2004, 22:15
  5. Def. Problem, Car not starting when cold!
    By charTT in forum TT/TT-S/TT-RS Forum
    Last Post: 14th April 2004, 22:10
