Chris NottMonster Motorsport
Thread: Wheel Offset
    Mar 2009
    449
    Wheel Offset
    If I have 2 different style alloys on the same side of the car, same sizes, tyres, width, et value, everything the same but just a different style, will the tyres be running parallel to each other.
    Basically , regardless of style as long as all values the same and et the same, this would run fine.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    StuG808's Avatar
    1.9tdi130 Avant FailWheelDrive
    Feb 2012
    Glasgow
    255
    Yes. What are you planning? Something different on the back than to the front? The only thing that comes to mind would be having two different weights of wheel on the same axle, the different unsprung weights messing around with the handling, wouldn't be recommended
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,712
    Just about to answer your PM Ryan. From what you've said the ET is the same between the wheels, it's just one has spokes which look aesthetically different to the others? If so, then as long as the ET is the same, the wheel will run the same trackwise etc, it just will look different (to the eagle eyed?) than the others.
    Mar 2009
    449
    Ok Thanks guys.
    Stu, Good point about the weight, hadnt thought about that. I just have a bit of a temp problem, until i can find another rim the same, I have 3 exactly the same and one ever so slightly different. Same type of style though and i would have thought the weights would be almost identical.
    James, can you believe the situation. LOL.
  1. 17" wheel offsets
    By KennyBradley in forum Handling
    Last Post: 19th December 2004, 14:15
  2. Wheel offset
    By QuantumJohn in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th December 2004, 17:16
  3. Wheel Offset Problem??
    By hitby in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th December 2004, 08:43
  4. Wheel offset
    By AndyC in forum General Technical / How To
    Last Post: 5th December 2004, 17:05
  5. What wheel offset?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2004, 11:27
