AH FabricationsSky Insurance
Results 1 to 15 of 15
    Mar 2012
    188
    The dread flashing oil can, 1.8t 190 quattro
    There i was tootling along the M62, well not exactly tootling i was certainly doing sum, and the red oil can warning appears on the Dis with oil pressure written there for good measure.
    Oh fiddlesticks says I, oil pickup pipe shagged. So I pull of the motorway quick sharp and turn the car off. Bear in mind im still 45 miles from home. Start the car after it's cooled down somewhat and the oil can does not appear, so i tentitively rev it to 2k and still no oil can. I'm stuck in the middle of nowhere so I make the hard decision to drive home. Now I've only had the car 2 months and the plan was always to get the pickup changed as a bit of preventitive maintenance but i had put it off based on the fact that the car had been serviced yearly and over the last 5 years had had the oil changed at 7k intervals. So i used this fact coupled with that I had recently changed the oil and added the larger oil filter within the last 3 weeks as the basis that if i took it easy i would be able to drive home.
    So off i set keeping it at or below 2k revs (not easy on a motorway) listening for any sort of unusual engine noise or the oil light coming back on. Luckily got home without any further incident.
    So it's going to my local trusted indy tomorrow to get the pick up pipe replaced, I was wondering wether it would be worth getting the oil pump changed at the same time? Or can i assume that the pump is ok?
    Jun 2010
    warwickshire
    93
    I would have it done while they are there imo
    Mar 2012
    188
    Does it make any difference that there was no beeping when the oil can appeared? Could it be something else?
    Mar 2012
    188
    £115 + vat from my local Indy to replace pick up and clean sump. Booked in for Monday.
    Mar 2012
    188
    And 180+vat including the oil pump. So getting both done. The car is about to turn over to 100k miles so probably for the best if I get both done.
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    That's a good price might have to get mine booked in too
    A4 1.8T 190 S-Line, Stage 2 Shark Performance Map 230 BHP, Pipercross Panel Filter, Forge 007 DV, Blue Flame Performance Exhaust + High Flow Sports Cat, 8k HID Lights, 8k HID Fog Lights, LED Sidelights, LED Number Plate, Front + Rear Ambient Lighting, LED Interior Bulbs, Grooved Dimpled Disks, Ultimax Pads, RNS-E DVD, Tinted Windows, S4 Grill, Votex Rear Skirt, BOSE, Leather, Engine Covers, S4 Mirrors, RS4 Pedals, Gloss Black Wrapped Grills, 19" BBS LM's Summer, 19" RS6's Winter, Coilovers
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    oil pump with the pick up pipe is very good working practice m8
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Mar 2012
    188
    Yeah I thought the price was good. I think he must be going to attempt it with out removing the sub frame.
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    228
    You dont need to take the sub frame off, I did mine a couple of weeks ago
    Oil Pickup change 1.8T
    Proper pain in the @rse though!
    Audi A4 1.8T S-Line Quattro (190) '04
    VCDS HEX-USB+CAN
    Mar 2012
    188
    Well just picked the A4, the mechanic showed me the pickup and it was clogged up with not much room for any flow. The sump also had plenty of thick gunk in it.
    The checked the oil pressure prior to doing the work and it was well within spec so it just goes to show that there's no way to check for this issue without taking the sump off.
    Also this car only spent two years on AVS with the rest of the time spent having the oil changed every 7k miles. So the moral of the storey is that if you've got a high mile 1.8t then you need to get this work done ASAP.
    It was slightly more than quoted, the bill came in at £182 + vat.
    Whilst there I got a quote for a new clutch, £360 for a LUK clutch kit fitted, any good?
    Johnney1985's Avatar
    May 2012
    dartford kent
    19
    Just had the exact same thing on my a3 1.8t, ive left it down the road to cool down. hopefully when i go back to it the light will stay off and give me a chane to change pump and pick up.
    Mar 2012
    188
    Good luck. Hope it works out for you.
    Pabs's Avatar
    Jun 2010
    Manchester
    617
    Where is this garage Duffy £360 for a clutch fitted is very cheap I have had prices from £500 to £1300 depending on type of clutch etc...
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,480
    Quote Originally Posted by Pabs View Post
    his price is without DMFW
    yours prob is including the dmfw
    Mar 2012
    188
    The garage is in Middlesbrough called Ron Turnbulls, I can highly recommend them And it is only for the clutch, but most places will be unless you specifically ask for DMF.
    This will be the 4th car they have looked after for me.
    1. MKIV Golf V5 170,
    2. MKV Golf GTi,
    3. VW Touran 2.0 TDi (still have this one)
    4. Audi A4 1.8t 190 Quattro avant.
  1. EPS Flashing
    By Lincoln S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2011, 21:06
  2. Fueling probem. Flashing engine light. 2.5TDI Quattro
    By haytch75 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th April 2011, 16:12
  3. Newbie 'What type of Oil' question
    By bluerouter in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2011, 08:28
  4. Indicators not flashing as they should
    By Izzy1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th November 2010, 14:41
  5. 'oil' flashes on start up
    By a4cam in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th January 2008, 15:55
