    May 2004
    Kent
    179
    Loose connection on Indicator
    My front-left indicator keeps giving up on me and annoying me with the DIS beeping and double-speed indicating. It's done it ever since I've had the car and just meant I have to pull out the light unit and re-tighten every 2 or 3 months.
    Ever since my neighbour reversed into the front of my car a few weeks back, its now happening all the time. The last straw was on Sunday when I tightened it up, drove down to the shops and it went again after 2 minutes!!
    Is there anyway I can replace the bulb holder thing which screws into the light unit myself (which is presumably the problem), or do I have to take it into a dealer?
    Mike
    Oct 2004
    Bedford
    74
    Re: Loose connection on Indicator
    I've been having exactly the same problem and have literally just got back from the local dealership.
    They replaced the bulb and the mechanic said that the contacts were slightly mis-aligned and he bent them slightly, to make a better connection. Cost 17 but I couldn't face the grief of trying to access the back of the headlight unit.
    Might be worth trying on your car.
    Good Luck.
    Matthew
    Dec 2003
    Clarkston, Michigan USA
    247
    Yes, my guess is that it's the contacts and the fix that Matthew posted is probably what needs to be done to your headlight too.
