Chris NottSky Insurance
Results 1 to 9 of 9
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Thumbs up WHEEL AND TYRE SIZE EXPLAINED (also list of tried and tested wheel/tyre combos)
    TYRE WIDTH:
    Also called 'section width'. This is the width of the tyre in millimetres (mm). So if a tyre is 235/40/18, the tyre is 235mm wide (9.25 inches/23.5cm).
    TYRE SIDEWALL:
    Also called 'sidewall aspect ratio'. This is the measurement of the side wall of the tyre. It is not a cm/inches measurement, but a percentage of the tyre width.
    For example, a tyre size for a 195/50/15 tyre could be read as '195mm wide/50% of 195mm = 97mm sidewall height/15inches wheel size'. So the sidewall height is actually 97mm (3.8inches/9.7cm).
    TYRE SIZE (WHEEL SIZE):
    This is the size of wheel the tyre should fit onto. For example, a tyre size of 235/40/18 should be suited to an 18inch wheel.
    WHEEL SIZE (DIAMETER):
    This is the usual term for describing wheel sizes. An 18 inch wheel has a diameter of 18inches.
    WHEEL WIDTH:
    When looking to fit new wheels you need to know how wide they are. This is usually stamped on the rear of the alloy, followed by a letter. Usually, it is something like '8J', where the '8' means '8inches wide'.
    STUD PATTERN:
    Also called the 'PCD' (pitch circle diameter). This is the number of wheel bolts per wheel and the pattern they form on your wheel and hub.
    For example, your average Audi A4 has a PCD of 5x112. This means 5 bolts per wheel, set out in a circle measuring 112mm.
    OFFSET:
    This is the distance in millimetres from the wheel hub on the car to the centre of the wheel.
    In simple terms, a wheel with an offset of '35' will stick out more from the arches than one with an offset of '55' (assuming all other wheel measurements are the same/wheel width etc). Some people use 'spacers' that sit between the wheel and the hub to make their wheels stick out more. Adding a 10mm spacer would reduce the offset by 10mm.
    **PLEASE ADD YOUR 'TRIED AND TESTED' WHEEL AND TYRE COMBINATIONS BELOW TO GIVE OTHERS AN IDEA OF WHAT WILL AND WON'T FIT. ALSO ADD YOUR VEHICLE MODEL AND ANY RELEVANT MODIFICATIONS (LOWERING SPRINGS ETC)**
    Also, links below (thanks to myturbodiesel.com) for OEM Audi wheel sizes for 5x100 and 5x112 wheels:
    16" and 17" Audi stock wheel gallery database5x100
    18" VW and Audi wheel picture gallery and database 5x100 bolt pattern
    15" and 16" audi OEM wheel pics 5x112 bolt pattern
    17" Audi 5x112 wheel gallery
    18" Audi 5x112 wheels
    19 20" 21" VW and Audi wheels 5x112
    *WANTED* AUDI CD PLAYER
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    B6 Audi A4 Avant 1.9 TDI Sport.
    TYRE SIZE: 235/45/17.
    WHEEL SIZE (DIAMETER): 17".
    WHEEL WIDTH: 7.5J.
    STUD PATTERN: 5x112.
    OFFSET: ET45.
    Apr 2012
    lincs
    210
    there's many a tyre size calculator out there but here's one:
    TRC Calculator
    as you posted (in the other thread) it's the Rolling radius that's important (douby so with a quattro / permanent 4wd)
    also that 235 in a michelin isn't necessarily 235 in a Goodyear. The amount of rim protection and side wall shape profile can all be signiificant. I had a Volvo V70 on 18" BBS split rims (i didn't pay the £1800 option price mind) and they were fine on vredsteins but not goodyears due to front wheel scrub on brake line / inner wheel arch.
    I run Michelin Pilot sport2's on S4 Avus 18s et 45 8 inch rims and 235/40/18's and they're normal load (as far as i can determine even a behemothic barge like mine still runs on normal load tyres). Not surprisingly they run without issue with the std 20mm lower sport chassis.
    PCD is a little confusing as it's the circle drawn from the centre of the wheel through the centre of the wheel bolts (hence USA use Bolt circle diameter (BCD))
    and not forgetting that a tyre could have 9mm of tread or 2mm of tread (+/7mm on radius and 14mm diameter or twice pies x o/a radius rollling)
    cheers And
    Apr 2012
    lincs
    210
    Wheel Bore
    The B6 / b7 wheel bore is 57.1 so you'd need spigot rings to fit wheels with larger bores A4 B8 model or A5 wheels.
    So smaller wheel bores wont fit without machining (expertise?)
    Here's a link to a list of cars that use 5 x 112 pcd and 57.1 bore.
    PCD Audi A4 B5 (1994 - 2000) wheels -Wheel Fitment.eu - PCD, Offset and Center Bore data
    And
    Apr 2012
    lincs
    210
    Replying to my own thread - quattro's are marginal for 91y tyres - early s4's had them and the axle loading is right on the limit - "some owners with some tyres" had problems which might be explained by the relatively soft sidewalls.
    Audi, changed to min 94 tyres and it's my thinking that any B6 (apart from the 1.6) should probably have 94 load tyres on the front.
    There's a thread somewhere with the links when I can find it!
    A4 2.5 tdi Q sport '02 AKE, "minor modder", 18x8's S4 Avus , Zender Monza's 18x8.5's, aero wipes, interior trim, dis and cruise, real s4 mirror caps, rns-e led, dble din, VCDS owner-learner - GMBH next
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    I've been running these on my B6 Quattro for a couple of years:-
    19"x9.5" on all 4 corners <----------- For sale, cheap plug!
    ET38 all round
    Spigot rings fitted (no issues)
    235/35/19 tyres all round
    KW coilovers lowering the car approx 50mm
    No spacers, no arch work, no rubbing.
    Also taken delivery of my new wheels today, not far off of the spec of my old wheels above,....
    19"x9.5" on all 4 corners again
    ET45 all round
    235/35/19 tyres
    Obviously on the same coilovers lowered the same amount.
    This time I'm running 5mm spacers all round to give a final ET40
    As above, no arch work or rubbing.
    EDIT....... Wasn't happy with the finish of the new wheels so sent them back, ordered the same wheels as I currently have instead (OCD getting the better of me)
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    TYRE SIZE: 235/40/18.
    WHEEL SIZE (DIAMETER): 18".
    WHEEL WIDTH: 8J.
    OFFSET: ET43.
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    A3 version
    Tyre size: 235/40/18
    Rim size: 18"
    Width: 8J
    Stud pattern: 5x112
    ET: 54. Needs spacers or will rub on front on full lock, at least 15mm or more to look right.
    Jul 2012
    432
    A5 alloys
    245/40/18
    5x112
    ET 29
    8.5j
    66.6 centre bore (spigot rings sort that)
    Tyre could do with 235's to stop arch rubbing when going over bumps.
  1. Wheel, tyre and ETs
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st May 2012, 22:27
  2. Wheel & Tyre Help
    By HipAl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd April 2012, 19:02
  3. wheel offset and tyre sizes, need info please :)
    By liam_b in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th April 2010, 23:34
  4. Was after some wheel and tyre advise.
    By S3 HODGE in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2009, 12:46
  5. wheel/tyre sizes
    By goon in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th August 2006, 09:29
