EM TuningVolks Autos
Results 1 to 15 of 15
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Question 245/40/18 tyres - OK to run on the rear?
    Hi guys.
    Would 245/40/18 tyres be fine for the rear on my Avant Sport? I have two spare so I may as well use them if I can.
    Many thanks
    *WANTED* AUDI CD PLAYER
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    Wat size rims are they
    Quattro Jam B12 suspension kit ,Custom Droplinks F/B , HID 6000, 18" RS4 Alloys, summer AMG's .
    RS6 for Show's .Cat gone for walkees, sports six padded clutch DMF
    Remapped 173BHP///278lbft, RS4 F/R ARB's , happy with that ........
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Quote Originally Posted by pink.teg View Post
    8J x 18".
    ET43.
    The width should not be an issue but I think the rolling radius will be out a little
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,711
    Rolling radius shouldn't matter on the rear, assuming your car isn't a quattro.
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Nah it FWD. I meant in relation to space in the rear arches over bumps and such
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    In that sence ... No problems
    i have a Quattro
    and have 234/40/18 on front
    245/40/18 on rear and it's fine
    was on RR and the bloke that set up my map asked !
    and said the read out was fine !!
    Jan 2011
    570
    245 is the width of the tyre and will not have any effect on the rolling radius, 40 profile is right for 18" wheel, you should be fine with these, it's only 10mm wider than a normal 235....
    03MY 52 reg 1.9 TDi 130PS Quattro Sport Avant - 170bhp remap, RNS-E+OEM bluetooth, B7 wiper arms/blades, 4300K HID+nightbreakers/LED sidelights, rear tints, new lights all round, new front/rear screens, frt armrest, s-line kit, cruise/DIS, B7 gearknob/aluminium trims, parking sensors, black grilles, RS4 RARB, S4 front end, black 18" RS6 alloys
    Still waiting..... S4 rear bumper, exhaust tips, coilovers, leather recaro's.... phew...
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Quote Originally Posted by jbcalvin View Post
    245/40 has a larger rolling radius than 235/40, as the 40 represents a percentage of the 235/245.
    So 40% of 245 = a bigger overall tyre than 40% of 235 (iirc)
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,471
    See the tyre size calculator here Cheap Low Price Special Offer Alloys and Tyres from TYRESAVE
    235/40 x 18 has an overall diameter of 245mm, but 245/40 x 18 has an overall diameter of 653mm, i.e. 8mm or 1.24% larger.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,579
    i have a Quattro
    FWD should be fine to run different rolling radius tyres, but you are putting a lot of completely pointless strain on the quattro differential by doing what you're doing... it'll run fine on RR or on the road, but it just works the differential constantly...
    LostBok/BahnStormer77
    pink.teg's Avatar
    Jan 2012
    Cardiff
    170
    K
    will wack the 235's back on ASAP then
    Cool save them for the dry summer days ...
    BahnStormer
    Feb 2009
    Surrey
    2,579
    other thing to bear in mind for anybody who's got FWD and wanting that hot-rod stnad with slightly chunkier tyres on the rear... it may seem really obvious, but wider tyres = more grip... so the back will grip more and increase understeer...
    One of the later model Polo GTI's (2008?) has NARROWER tyres on the back to give the car a more neutral balance on the limit
    Mar 2008
    Dorset
    13,711
    Quote Originally Posted by lostbok View Post
    I 'think' RS3's do too.
    DIESEL DOG
    Mar 2011
    Middlesbrough
    Will 245/40/18 on 8j et 43 go on the avant sport front and rear as i have a full set from an a6 but unsure if they will fit.
    Grey A4 Avant Sport B6 1.9 TDI
    Apr 2012
    lincs
    202
    Quote Originally Posted by avantsport View Post
    they'll be about 2% bigger (RR / circumference ) than standard 215/55/16 baseline
    Tyre Calculator - Alloy Wheels - Specialist supplier of alloy wheels and tyres packages, Fast Delivery, Buy Online.
    gives you loads of option for tyre width / size.
    don't know about width (+5mm both in and out) but if people are running spacers and 35 et's then the ouside 'rim' shouldn't be a problem
    don't know about the 5mm nearer inner wheel liner though.
  1. 9" REAR tyres on Bentleys possible ??
    By doug.p in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st February 2012, 13:30
  2. Is it possible to have Diffetent tyres front & rear?
    By dplovin in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2012, 17:13
  3. Will my rear tyres fail an MOT?
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th September 2011, 10:46
  4. Tyres : 225 45 17 front 235 45 17 rear ?
    By alictait in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd January 2011, 07:35
  5. Best two tyres on the front or rear??
    By Ads in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th July 2010, 06:59
