Chris NottSky Insurance
    Quattro180's Avatar
    Oxfordshire
    101
    No warning beep when lights left on?
    I recently realised that me & the mrs have been leaving the headlights on because the warning beep has stopped working. The warning beep for low fuel & other warnings also no longer works.
    The beep always used to work? Is this just a case of the beeper broken or something else?
    cheers
    2004, A4 Avant SE, 1.9tdi 130. Gunna do s line or s4 body upgrade
    WANTED - sport suspension, front s line or s4 bumper, door blades, 17" s line 5 spoke alloys, rear roof spoler
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    does your dis display the door open on the drivers side ??? if not you need to check the wiring inside the rubber boot between the door pillow and the door frame quite common for the door wiring to break...
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,197
    Quote Originally Posted by marktdisport View Post
    How would that stop the low fuel warning etc from working?
    the buzzer will have most likely packed up and it is located on the rear of the instrument cluster, i dont know of anyone yet who has changed it sucsessfuly.
    Like you mine has done the same i am waiting for a cheap donor cluster to attempt a change
    Quattro180's Avatar
    Oxfordshire
    101
    Quote Originally Posted by swarcup View Post
    Sounds like its packed up!! The dis still displays that the door opens.
    What a pain in the arse!!
    Jul 2011
    mids
    1,193
    sorry my mistake i must not of read it correctly
    A4 TDI 130 SPORT..
  1. Lights left on warning, not working?
    By daveyb0y in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd March 2012, 23:31
  2. Low fuel warning beep
    By CocnutMacaroon in forum A2 forum
    Last Post: 26th May 2009, 13:11
  3. No warning noise when lights are left on!?
    By Technik in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th September 2008, 20:38
  4. 3 BEEP WARNING?
    By DIPS_A4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th May 2006, 21:30
  5. A4 Warning Beep !
    By wigginer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th October 2003, 09:02
