AH FabricationsEM Tuning
Results 1 to 9 of 9
    Mar 2009
    11
    Question Central Convenience Module 8EO 959 43 AJ
    Hi
    Has anyone got a working CCM 8EO 959 433 AJ to replace a possibe faulty unit which is bone dry but displays the symptoms of a faulty unit.
    Please beaware that the budget is not great.
    Any help on the matter is great.
    Thank you
    Grover
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    thats an old unit and that part number has slightly changed, i learnt this as i had to do my one, you wont get one 2nd hand as i learnt the hard way, they do cost about £155 from the main dealer and it will need reprogramming to your keys, sorry to be the barrer of bad news but thats the truth mate,
    amz
    Sep 2011
    184
    Quote Originally Posted by Turkster View Post
    Main dealer price is £289! I know because I just had mine replaced, luckily I sourced out a second hand one after ringing hundreds of breakers.
    @ Grover: I know one more person that has the Control Module with our identical part number that you require because I needed the same one. PM me asap!
    Turkster's Avatar
    Dec 2007
    2,713
    Quote Originally Posted by amz View Post
    its gone up that much? wow!
    amz
    Sep 2011
    184
    Exactly mate. They're not called main stealers for nothing lol.
    Mar 2009
    11
    <br>
    <br>
    My original unit is 8EO 959 433 AH and thought the replacement part for this the AJ (ETKA). Didn't know anything about reprogramming? Can we do this in VCDS Lite? If not will like for like for like AH replacement do without any reprogramming?
    Thanks in advace
    Grover
    amz
    Sep 2011
    184
    Quote Originally Posted by Grover2000 View Post
    <br>
    <br>
    Thanks in advace
    Grover
    AJ (EKTA) is the current replacements for our cars as far as I'm aware. About reprogramming do you have 2 keys? And also this guy that I spoke to is selling the unit for £80 delivered!
    Sep 2012
    10
    CCM repair?
    How can I repair the CCM? What is the most commom problem wich lead to CCM fault?
    In VAG-COM their's no fault in 46 unit. But the car don't go to sleep mode and it's drain the
    battery.
    First there was problem with te safety lock, but I repaired that.
    Than the sleep mode works for a short time, than again hazard switch blinking and drain the
    battery.
    Some auto electrician said the he thinks the CCM is faulty. Everything works perfect (I think)
    except the sleep mode.
    In the attachment you can find the 8E0 959 433 AJ PCB.
    Sep 2012
    10
    Problem solved! Now the current draw is 20-30 mA when the car is in sleep mode (it was 700 mA).
    It was a badly installed alarm system, wich one I take completely out and throw away. After that pull out the 09 Central Electric connectors and woala the system activate the sleep mode within 1 minute after lock the car, and no Hazard switch flashing.
    This problem was in the car since i bought the car, but didn't noticed that only after the battery died. I took the car to manny technician but noone could solve the problem. These are the local "professionals".....(no comment)
    Thank God I didn't bought a CCM like one technician suggested, I knew won't be the CCM faulty (I hoped also).
    I hope won't be other problem with the electrical system.
  1. Convenience module
    By N80KRR in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th August 2011, 21:24
  2. Central convenience 8E0 959 433 BD match?? wanted
    By sabs46 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 6th February 2011, 11:38
  3. Convenience module
    By Mpathe in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2009, 22:59
  4. i think i short circuited my Central Convenience Control Module???
    By ForthRightAfter in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th January 2008, 19:42
Tags for this Thread
