Chris NottJMB Retrofits
Results 1 to 17 of 17
    amz
    Sep 2011
    184
    Audi A4 B6 19" Alloys - How Low Can I Go Without Rubbing?
    Hi all,
    How low can I go on 19" RS4 alloys without facing any rubbing issues? I obviously don't want to go right to the ground because of humps, and I'll also be putting on the Votex kit also.
    Any ideas?
    CMD
    CMD's Avatar
    Pointing Forward's!!!!!!!!!
    Nov 2008
    S. Wales
    3,021
    That's up to you and your choice suspension .
    AUDI A4 190T S-LINE.
    amz
    Sep 2011
    184
    I have coil overs. I want it low enough where the top of the tyres are almost level with the arches, but I don't want to face any rubbing issues! I don't have 19" RS4 alloys yet, if I will be facing rubbing issues then I might have to stick with 18" alloys.
    Quote Originally Posted by CMD View Post
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,423
    you will have to adjust till you get what you want
    theres no way anyone on here can tell you
    amz
    Sep 2011
    184
    All I would like to know is will I get any rubbing against the arches issue if I was to put on RS4 alloys with 235/35/19, if it was pretty low?
    bez101's Avatar
    Jul 2008
    8,423
    no idea you dont mention what coils you have
    or what wheels tyres you have now
    they may rub they may not
    thats why i said you have to lower till your happy theres no rubbing
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Quote Originally Posted by amz View Post
    I have no issues with 235x35x19 rubbing on my arches .
    amz
    Sep 2011
    184
    Thank you CMD. Atleast now I could go ahead with buying a nice set of 19" RS4's without worrying about rubbing against the arches :D
    Fraggles's Avatar
    Jan 2012
    31
    I've got 19's and weitec GT coilovers. The rears are wound all the way down and the fronts to match the height of the rears and I get no rubbing. You'll want to be slowing down for speed humps tho!! lol
    amz
    Sep 2011
    184
    Quote Originally Posted by Fraggles View Post
    I've got entry level coilovers tbh mate FK AK, not the best I tell you as I didn't want to spend too much, but still does the job
    I'm looking to put spacers in aswell to get the wide look as mentioned in one of my threads.
    How about when the car is a full load, does it rub?
    Aug 2004
    67
    Like others have said , you have to get it all fitted then adjust the coilovers until you are happy. Had the same thing with a mk4 Golf in the past, coilovers and 19's. I just wound it down until it rubbed , then wound it up a bit!
    2004 A4 Avant Sport TDI..
    Jan 2009
    Derby
    20
    You can go pretty low with no hassle
    Ive got 20's tucked with kw v2's and have had 5 up with luggage on an airport run with no problems
    amz
    Sep 2011
    184
    Quote Originally Posted by SammA3 View Post
    Lucky you! lol. Right! 19's it is
    Fraggles's Avatar
    Jan 2012
    31
    Yeah I've had 5 up on B roads with my set up with no problems to speak of in the arches, I've scraped the underside on harsh speed bumps once or twice tho when I've got passengers in the back.
    amz
    Sep 2011
    184
    I see, it might be worth getting the arches rolled?
    Jan 2009
    Derby
    20
    Arches are huge, don't need rolling
    I would just whack your setup on, play with the height, look and admire your work!
    CMD
    CMD's Avatar
    Nov 2008
    S. Wales
    3,021
    Correct no need to roll the arches, if you were going 9.5"- 10" rims with a fall out decking then maybe.
