brake discs
deburgh999
managed to get hold of a set of 996 front calipers now just need to source discs, need either 330mm x 28mm or 30mm pcd 112, does anyone know or recommend discs and pads? heard to use ferodo ds2500?
Ferodo DS2500 are good sport pads,but u have to use them with sport discs,like brembo max,zimmermann,etc.
Guess I best start searching for these type of discs, just don't know what brand to go with!
Think I'll give brembo a ring Tuesday to get advice and prices. Found Audi q7 rear discs are 330mm x 30mm? Wonder if these would work?
Not sure if the Q7 rears would work, I will probably get corrected shortly, but I thought rear discs were predominantly non-vented as it is the fronts that do "most" of the work....
After doing alot of searching I think I'll run with 321mm x 30mm discs and matching branded pads, just have to decided who now, zero sixty, brembo, ebc or tarox.
12
3K
11
954
23
11
2K
17
16K
