JMB RetrofitsVolks Autos
Results 1 to 17 of 17
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Question Diesel fuel filter change - 1.9 TDI 130
    Does anyone have a walkthrough?
    I can locate the fuel filter to the right of the engine and it looks simple enough, any tips however?
    I changed a million and one (exaggeration lol) diesel filters back in my Peugeot days but as with any new job always worth an ask!
    *WANTED* AUDI CD PLAYER
    rawtor51's Avatar
    Jan 2011
    Aberdeen
    233
    Straight forward enough.
    I went and filled a gerry can with some new fresh diesel before i started too.
    Pull out the R clip, pull the plastic piece up out of the filter ( remember to change the litte "O-Ring"
    now move onto the other hoses, remove them by squeezing the wee clip together and the hoses just pull off , may take a little wiggling though.
    Unscrew the clamp that holds the filter in, pull out the filter.
    Unpack the new filter make sure the drain on the bottom is tight.
    Fill it with new fresh diesel, I dont know if this is essential or not but thats what i did.
    Pop it into the clamp and tighten the screw to hold it in place.
    connect the hoses you removed,
    Plug the plastic hose bit back in and put the wee R clip back in.
    Clean up and hey presto.
    car should fire back into life no probs.
    Hope that helps
    Ross, MK5 Golf - R19 DUB, Audi A6 C6 - R19 RRW
    Oct 2009
    Hull
    1,442
    As above only I have never filled any of mine and had no problems
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Thanks guys.
    Any tips to avoid getting diesel all over the place?
    I prob will go with the pre-fitting diesel fill
    Oct 2009
    Hull
    1,442
    Yes hold it straight when removing that's all you can do
    Seriously I wouldn't bother filling it I never do and not had any issues
    Jan 2012
    Warrington (NW)
    118
    you only need to pre fill diesel filters if the vehicle dosnt have a lift pump to squirt fuel into the filter on turning the key to ingition, older type diesels need priming manually and can sometimes take a bit of turning over to get rid of the air lock. a lot of modern fords are like this and are an absolute tw@t to get going mostly.
    the way to tell if your car has a pump is to leave the fuel pipe which feeds the fuel filter off, switch ingition on , check for fuel and switch off straight away. then prime the filter by fitting that pipe and removing the exit pipe which feeds the engine, switch the ingition on and off until fuel comes out which then means the filter is fully primed,put pipes on and that should be it.
    the a4 diesels have a lift pump so the way to prime the filter is as above
    scottshere's Avatar
    Dec 2010
    South Yorkshire
    337
    It will prime its self
    I have never filled mine and it was fine
    Turned the ignition on and off a few times (to fill the filter with fuel) then it starts first time smooth as anything
    Be careful with the black clip as i have heard these break easily
    A4 1.9TDI Sport - 130 (B6) / Mods: None yet, just getting the basic right first
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    So to prime, just turn the ignition on and off a few times with the feed from the filter to the engine disconnected?
    Is that just the initial turn (glow plugs etc) or a full crank of the engine?
    Oct 2009
    Hull
    1,442
    Just connect it all up and start the car I will put money on that you have no problems
    I have done it 4 times on my motor no trouble at all
    Oct 2009
    Hull
    1,442
    just checked on elsawin and you dont need to bleed the system at all
    Vehicles with 4-cylinder or 2.7 ltr.; 3.0 ltr. 6-cylinder engine
    Due to the design of the engine, with a fuel system pressurisation pump located in the fuel tank, it is not necessary to bleed vehicles with unit injector and common rail engine.
    The fuel system bleeds itself when the starter is operated.
    Apr 2012
    202
    Best way to fill up a new filter is fit the new filter connect all the pipes up then a few on and offs of the ignition to get the lift pump to prime the system. Try to get some air out the system as the high pressure pumps don't like to run dry for long.
    Jan 2013
    Bath
    69
    Dragging this back up... Turned my ignition on and off countless times but it still won't start...
    Do all diesel a4's have the lift pump? Pretty sure I can here the pump working but still won't start. Any ideas?
    S3 GAZ's Avatar
    Dec 2006
    East Ayrshire Scotland
    347
    Re: Diesel fuel filter change - 1.9 TDI 130
    Keep trying. I ran my battery flat trying to get it going
    Jan 2013
    Bath
    69
    Got it! Cheers, took much longer than I was expecting!
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,579
    I wish I filled mine when I did it as I had an air lock. Popped a hose off to release the air then reattached and it started after that.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    S3 GAZ's Avatar
    Dec 2006
    347
    Quote Originally Posted by Steffgj View Post
    Glad u got it going mate
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Mine was similar too, it took a lot longer than I had thought it would. I had the wife hanging out of the window frowning at me, at first I was jovial but it soon turned sour when I thought she might be right that I'd break it. When it fired up it was a tried moment of joy! Glad you got it sorted.
  1. A6 2.7 tdi diesel fuel filter
    By Rallyboygower in forum A6/S6/Allroad forum (C6 Chassis)
    Last Post: 21st March 2012, 17:48
  2. 1.9tdi 130, n00b owner, fuel filter query
    By StuG808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th February 2012, 22:03
  3. Diesel fuel filter change 2.5 V6
    By owdgit in forum Diesel forum
    Last Post: 30th October 2010, 17:00
  4. 2.0 tdi diesel fuel filter change procedure
    By RGC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2010, 16:48
  5. V6 Drain Diesel Fuel Filter - Help
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th June 2008, 21:58
