Monster MotorsportVolks Autos
Results 1 to 9 of 9
    May 2012
    audi a4 b6 stereo system HELP!!
    Hi can anyone help! Just recently bought a after market head unit and had it fitted in my audi, since having it installed i can not turn the volume above 15 as sound keeps cutting out/jumping, sounds like speaker wire arking out but checked all speaker wires and connections and thats not the problem, Can anyone help please
    dj0nes's Avatar
    Mar 2012
    16
    I might be barking up the wrong tree completely here but it may have something to do with the Amp clipping the power for whatever reason.
    Someone who knows what they are talking about will be along soon but in the meantime let us know what head unit you have and whether you have the Bose sound system.
    May 2012
    hi thanks for the reply, the head unit taken out was a audi concert and has been replaced with a jvc head unit, the amp only seams to run the rear speakers and sub, i have dissconnected the amp but was still cutting out the front door speakers
    Jul 2010
    184
    What aftermarket wiring harness are you using? Non bose setup?
    May 2012
    tryed both harnesses( bose one) didnt power the amp up from the jvc head unit so had to opt for the none bose harness
    Jul 2012
    24
    did you solve this problem? I'm having the same problem too
    Inertiauk's Avatar
    Mar 2011
    529
    Could it be that the because factory speakers are 1ohm and the JVC expects higher resistance from the speakers, so when you increase the volume eventually the JVC unit thinks there is a short and goes to 'protect' mode.
    __________________________________________________ __________________________________________________ _
    Driving a 2004 B6 Audi S4 - Stage 2
    Jul 2012
    24
    sounds plausible, and an easy fix, but time consuming, fix. Just solder in a lot of 1ohm resistors to all the speakers behind the head unit or replace the speakers.
    Oh ye, my head unit is a JVC too.
    Jul 2012
    24
    I spoke to a car audio specialist and he said to just turn the high pass filter on the head unit, means you wont get any bass sent to the speakers but that's not a problem if you have an after market sub
  1. Help needed with stereo system
    By Cookie0125 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2010, 22:36
  2. Upgrading Stereo System to Bose?
    By A_C4mby in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd March 2009, 11:30
  3. DVD/TV/MP3 Stereo System
    By ickleric in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th May 2008, 11:01
  4. fitting stereo system
    By rhubarb4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2008, 08:56
  5. Which Stereo system do I have?
    By Floob in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2007, 10:38
