Monster MotorsportEM Tuning
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Question does the..........
    does the front sub frame hold the engine in place? just im not 100% sure that it does, or is it there for front frame stability and hold the lower wishbones in place giving stability ?
    just having a blond moment here,
    Aug 2010
    1,540
    no not really, theres 2 ally bits on the n/s and o/s that bolt to the chassis legs that the engine mountings are on. but thru the ally bits is also another longer bolt that also goes thru the subframe mount too. the subframe mounting/bush is sandwiched between the ally bit and the chassis leg by this longer bolt.
