Sky InsuranceJMB Retrofits
    Apr 2012
    6
    2003 Audi A4 Avant - Boot Not Unlocking - Solenoid Removal
    Evening All,
    I have a problem. Basically when I use either the main unlock or just the boot unlock on the key fob I can hear movement but can't lift the boot. This, in fairness, has gradually gotten worse. At first I could open the boot, then occassional it would not fully dis-engage. Now it will rarely open the boot at all.
    I have tried pulling all the boot trim out (removed screws, pulled out the clips) but still not been able to fully remove the bottom trim from below the rear window. I have however, been able to see the metal rod moving to the left quite freely when I use the boot lift press pad. I think the problem is that it is not moving to the left enough and therefore not fully releasing the boot. I am sure the lock isn't seized and I can open manually with the key and I have lucbricated it with loads of WD40.
    My question is how do I fully remove the boot trim (bottom part and not all the trim around the top of the rear window) and also is the problem def with the Solenoid due to the fact it is working, although not enough?
    Any help would be greatly appreciated...
    Greeny233's Avatar
    Mar 2011
    Llangollen
    670
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    Just replaced the boot lock solenoid on my Avant had exactly the same problem, could hear and see the solenoid working. I replaced the solenoid with a new on and it now works a treat.
    To remove the boot trim is fairly straight forward, i managed to replace the solenoid without having to fully remove the trim. I just undid the 4 x screws in the bottom of the trim, 2 of which are behind the warning triangle compartment and just pulled it down which gave plenty of access to the boot solenoid, just 3 screws holding the solenoid in place and then un-clip the rod at the boot lock.
    If you want to fully remove the bottom trim once you have taken the screws out then the are just 2 metal clips holding the trim in place an it requires a sharp tug to remove them.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    Apr 2012
    6
    Your a diamond....
    Thought I might be able to get to it but could not see much advice online.
    How do you unclip to rod at the boot lock - Is there a knack?
    Also got to replace the coolant temp sensor tomorrow so loads of fun!!!
  1. Boot solenoid
    By V8Guzzler in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th June 2013, 17:31
  2. Part Number required - Tailgate Solenoid 2003 B6 Avant
    By terryp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th April 2012, 19:20
  3. Boot problem, solenoid replaced!
    By EPboi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th April 2012, 17:56
  4. b6 Avant boot trim piece removal - access to wiper
    By Jimmeh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2010, 00:12
  5. 2007 AUDI A6 AVANT BOOT PANEL REMOVAL
    By nigel1955 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd November 2009, 13:01
Tags for this Thread
