Chris NottMonster Motorsport
Results 1 to 9 of 9
    bowen's Avatar
    Mar 2011
    456
    another cooling fan thread!
    I was fixing/nosing around at my SAI to fix a code i had pop on on friday, when i noticed something else.
    My engine cooling fans dont come on?! So i searched here for an answer. Most people seem to have an issue with pulsing fans or fans that wont turn off.
    I put the A/C on an the fan began to spin. When the A/C is off there is no fan running.
    What process of elimination should i take next?
    Thanks once again!
    Audi A4 B7 SE S line TFSI Quattro.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    havent the 1.8t got viscous fan like the tdi's ??? the air con switching an electric fan on is normal
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by marktdisport View Post
    That's my thinking too.
    Oct 2009
    Hull
    1,440
    mine has a viscous fan and an electric one mines a 1.9 tdi avb engine code the electric fan on the right is for the AC and will only come on when the AC needs it
    if you have an electric fan on the left and its not on then dont worry just wait till the weather warms up and make sure it comes on in hot weather and your temp sensor doesn't go sky high
    it all sounds normal to me
    bowen's Avatar
    Mar 2011
    456
    OK, I maybe over reacting. I just went for a hard drive, got back and I would usually expect there to be a fan running.
    @Mark and James; My understanding of a viscous fan is that it should run all the time. Is that correct?
    Thanks for the speedy replies.
    Oct 2009
    Hull
    1,440
    yes a viscous fan runs all the time and is run from the auxiliary belt that does the power steering and alternator they speed up the hotter the rad gets
    bowen's Avatar
    Mar 2011
    456
    Thanks Stu,
    Well my viscous fan is not running, at all. Fuse? Relay?
    Oct 2009
    Hull
    1,440
    a viscous fan is not run from electric! no fuses no electrical power supply
    a viscous fan is the design of it have a read of this Fan clutch - Wikipedia, the free encyclopedia
    if your fans are electric they wont run till they are needed
    Jul 2011
    mids
    1,193
    yeah a viscous fan will just free wheel with engine revs and when it hits the temp it works at it locks in and fires up... doubt you will hear it working they are very quite at the best of times..... if you been for a hard drive it must work if you aint going over 90 oc
    A4 TDI 130 SPORT..
  1. Need a new cooling fan
    By Stink in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd November 2011, 15:52
  2. Cooling fan problems...
    By A3-sport in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2009, 10:50
  3. Cooling fan
    By d18ony in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2009, 19:21
  4. Electric Cooling fan
    By Robc in forum General Technical / How To
    Last Post: 18th July 2006, 14:43
  5. Cooling fan / viscous coupling
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st March 2006, 08:59
