Chris NottVolks Autos
    Mar 2012
    24
    Potential air leak re turbo, help please
    Hi guys, i'm looking for a bit of help as I have a problem with my A4. Basically the car runs quite inconsistently and I think it may have an air leak near or to do with the turbo. Sometimes when i drive the car, when the turbo kicks it, its really torquey and seems to pull like a train. Other times when I drive it, it accelerates really flat, almost like the turbo isn't working. I've changed the petrol filter as we suspected it could be that and it didn't solve the problem but also no engine lights have come on so it hasnt registered anywhere on the computer.
    I just wondered if there were any known common places on the engine/system where there could be air leaks or split hoses/pipes etc? I also have a small feeling that brakes may perform differently in relation to how the turbo performs (this is just a hunch) so thought it could maybe be a vacuum pipe?
    Any help is really appreciated as this is my first Audi and would like it to drive how its supposed to!
    Thanks in advance
    Bradley
    Oct 2009
    Hull
    1,437
    I would scan it for any faults as it sounds like its in limp mode at times
    beachbuggy's Avatar
    Surrey
    1,739
    Sticking actuator? If it gets stuck open then you'll loose boost, becomes unstuck and boost comes back. Either that or you have the opposite and your actuator is locked closed, either leak on pipe to actuator or faulty n75 this gives strong boost minute , lip mode the next when you've over boosted. Scan it for faults and check for vacuum leaks
  1. Air Con Leak
    By fergysteven in forum Air Conditioning
    Last Post: 18th June 2011, 12:32
  2. turbo problem air leak and breather valve fault
    By 10blazin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th March 2009, 18:23
  3. b5 s4 AIR LEAK
    By S4SIMON in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th May 2008, 19:51
  4. air bag problem on potential new a4. is it easy fix?
    By shufti in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st January 2006, 17:54
  5. Air Leak
    By Jiny_P in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2005, 18:39
