Monster MotorsportChris Nott
    Apr 2012
    39
    Knocking from O/S/F suspension
    Sorry, probably a bit of a noob question;
    I'm getting a knocking (sounds a bit like CV joint) from the O/S suspension on my '04 130 TDI Multitronic. It has started doing it over some stutter bumps, but mainly does it when cornering hard left when throttle's under load, or when the car rocks slightly between reverse and drive.
    I've checked all the stupid arms for play, nothing. Checked the CV joints a few times as that was my first thought, nothing. I've ruled out the diff, as it just doesn't make sense for it to be that. All I can think it might be are possibly the top mount (is there a bearing in there? Audi say not :/ ) or the lower arm rear bush, which I know is chocolate on some VAg stuff.
    Any help would be greatly appreciated and will be rewarded by virtual cookies/Hobnobs.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    if it does it on a steering lock that usually points towards a cv joint.... have you checked the roll bar bushes they are very common but that would be all the time really....
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Apr 2012
    39
    It's not really on lock, more when you pull out of a junction with some speed, therefore putting a fair amount of weight/load on that corner. I will check the bushes tho, thanks .
    EDIT - Infact, it doesn't even need to have the steering turned. It's almost as if it's when there's force to pull the wheel back or forward, if that makes sense. That's what makes me think it's probably that bush or top mount.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,713
    could be the shock and top mount mate.
    Apr 2012
    39
    That's what I'm hoping it is, nothing more serious. I'll change it when I fit the coilovers. Thanks
  1. Suspension Knocking
    By way318 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th November 2010, 12:58
  2. Front suspension knocking
    By bonerp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th March 2008, 21:07
  3. knocking noise from suspension
    By Alba77 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th December 2007, 11:02
  4. Knocking on the front suspension !!
    By 951 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th August 2007, 10:26
  5. suspension fault knocking..
    By cominatcha in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th December 2006, 20:21
