EM TuningJMB Retrofits
    Mar 2011
    Chester
    167
    2.5tdi rocker cover gasket - any other stuff at the same time?
    I'm having a rocker cover gasket replaced next week (AKE engine). Question is......is there any other preventative maintenance I can have done at the same time?
    I'm getting my local Indy to do it but wondered if you guys knew of anything else I could get done whilst he's in there and got the pipes off?
    Thanks in advance.
    A4 (B6) 2.5TDI QUATTRO SPORT AVANT
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I'm getting mine done too soon. The only thing that springs to mind is replacing the return pipes off the injectors. These can perish and suck air in.
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    the return pipes and the brass washers that sit in the return pipe bases.
    Mar 2011
    Chester
    167
    cheers fella's.
    I'll look into getting these done......do you have much idea how much the parts cost?
    Jan 2011
    Aberdeenshire
    646
    I did my AFB engine which should be similar to your AKE, and the washers were pennies from Audi- remember you need 12 in total. The pipe I got from a factors and cut to the correct sizes.
    1999 A4 B5 1.9 TDi FWD Saloon, Green SOLD
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon, 'Panzer' Plated (currently sporting wrecked engine - and gearbox )
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue, 'Panzer' Plated, Cruise Control retrofitted, OEM 6 Disc Changer retrofitted
    2006 A6 Allroad 3.0 TDi Blue, awaiting stuff to be done!
  1. Rocker Cover Gasket...
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th April 2012, 09:42
  2. Cam/Rocker Cover Gasket
    By jojo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2011, 00:22
  3. Rocker cover gasket
    By MURRAYS444 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2010, 05:04
  4. Leaking rocker cover gasket
    By barker196 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th May 2009, 18:41
  5. Help - Rocker Cover Gasket
    By Erf in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th January 2007, 20:39
