JMB RetrofitsEM Tuning
Results 1 to 12 of 12
    9
    1.9 Tdi FWD Avant Multitronic MPG
    Hi
    I've got a 1.9Tdi Avant FWD Multitronic what sort of MPG are you getting, should I be getting.
    I'm only getting about 41 MPG, I'm driving like miss daisy to get that too, thats over the last 6 months.
    Car was serviced less than 6,000 miles ago, standard car, tyre pressures are good running 17's.
    Most journeys are mainly driving on B roads for about 30 mins to an hour, moving all the time and not suck in traffic
    Temp sits at 90 so I'm not sure whether the CTS should be changed.
    Jul 2007
    770
    Does it warm up quickly?Brakes not binding?I have a 2.5Tdi Quattro and would be glad to get near 41 mpg .The autos do seem much thirstier.Has the ATF been changed
    Oct 2009
    Hull
    1,437
    I'm averaging 43 in my 1.9 manual
    There is loads of threads on this already so have a search you will probably find its about right
    StuG808's Avatar
    1.9tdi130 Avant FailWheelDrive
    Feb 2012
    Glasgow
    255
    My 1.9 130 manual FWD is doing 38.8 MPG on the DIS which is poor. I'm about to fill up shortly, so see how it ties in with a manual calculation.
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,106
    I've just got 620 miles out of a full tank from brim full to zero miles on the dis ..... thats with Quattro and half and half driving miss daisy @ 60 motorway and the other half @ 80 with a small amount of town driving where i do tend to boot it a bit ..... quite happy with that
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    BahnStormer77's Avatar
    BahnStormer
    Feb 2009
    Surrey
    2,582
    I would have expected around 45mpg with a mix of town and motorway (70mph) cruising... depends on the B road, twists and turns, up and down hills would bring the mpg down a bit...
    "driving like miss daisy", I've managed nearly 55mpg on a full tank in a 1.9TDI 130.... in a 2001 VW Sharan (although admittedly a 6sp manual)!! Official MPG stats on that are 43mpg, versus a 130TDI multitronic A4 AVant which is 48mpg... what do you get if you reset the DIS and jsut run it at a steady 70mph on a flat stretch of road?
    If temp moves up to 90 and then just sits there, that sounds fine.
    LostBok/BahnStormer77
    StuG808's Avatar
    Feb 2012
    Glasgow
    255
    Quote Originally Posted by lostbok View Post
    I think the result of the DIS is misleading, the MPG varies a lot depending on even the slightest pitch change on the road. Even when rolling along an apparently even motorway with the cruise control on, the MPG reading can jump around a fair bit (on DIS current reading). The only real way to work out MPG is to record how many miles done between fillups and how many litres used, other methods such as 'brim to brim' / 'on a tank' leave a fair bit of margin for error.
    We should have a thread, maybe a sticky, where people can note their MPG readings based on both DIN reading and own calculations as the MPG issue comes up a lot, specially for us derv derp users.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I've said it before, but Fuelly | Share and Compare Your MPG is simple to use and provides accurate figures and easy comparisons..
    9
    Thanks for the replies.
    Brakes are not binding, MAF sensor was changed not done ATF. Gets to 90 temp within about 5 mins of driving.
    I've got the figs using MPG calculator an android app, B roads are not flat and plenty of bends.
    I was hoping with a diesel to get closer to 50MPG, I suppose that as the Avant is quite heavy and it Auto I should be happy with what I'm getting.
    Jul 2007
    770
    Quote Originally Posted by Family Wagon View Post
    All sounds in order.I think the ATF needs changing regulary on the Multi and fresh might help.I have a tuning box on mine which theorectically increases mpg but I cant prove it and a good one is about £400.I had a manual before and just accepted that there is a price to pay for an auto but its not getting any easier!!
    StuG808's Avatar
    Feb 2012
    Glasgow
    255
    Great idea, I've got mine showing below (still poor but reading about 4mpg above DIS):
    Mar 2008
    Dorset
    13,856
    With VAGcom you can calibrate the two.
  1. Replies: 0
    Last Post: 13th February 2012, 18:30
  2. 1.9 tdi 130bhp fwd vs quattro mpg
    By p1tse in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd April 2011, 09:53
  3. a4 avant 3.0 tdi multitronic thoughts on box??
    By J9NY X in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 24th January 2011, 21:51
  4. A6 TDi multitronic excessive MPG
    By denA6 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th December 2008, 19:47
  5. 130 TDi Avant Sport Multitronic economy
    By imported_aks in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th September 2004, 17:07
