EM TuningSky Insurance
Results 1 to 25 of 25
    afcjay's Avatar
    Aug 2008
    426
    Question Looking at a A4 3.0L Quattro Convertible.What should i look out for?
    My sis is after a Audi A4 convertible and ive got the job to find one lol.
    Ive found a 3.0L Quattro with 102,000 miles on a 53 plate at a good price and was wondering what faults i should look out for apart from the normal stuff oil/water leaks/clutch/smoke/ratttles/roof issues/shocks/brakes/exhausts/steering etc etc
    Im looking at manuals as ive heard alot about problems with the CVT boxes
    So apart from the Haldex oil/filters being done every 60k correct me if im wrong (could someone also tell me the cost to have it done)
    Also the cambelt/water pump being done (can someone also give me a rough price to have this done)
    Are there any know faults with the 3.0L Quattro????? Do they suffer from head problems (eg porus?) Any gearbox problems or any other issues that are common on these 3.0L models
    Many thanks
    3dr Dolphin Grey Audi A3 2.0 TDI S-Line
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    cats are worth checking as dealer replacements are somewhere neat 2 grand for the pair (of course you can get something made for a fraction of that. I have an S4 milltek cat back and s8 cats welded into the original downpipes). Do you have access to vcds/vagcom? It would be good to scan and see if there are any error codes there to give you a heads up. the cats can start to throw fault codes but will be sporradic for months before they become a problem.
    I haven't noticed anything else that's specifically common to the 3.0 though. Apart from wanting 2 turbos on it later
    Anybody selling a polisher? PM me.
    A4 B6 3.0 Quattro Sport Avant
    Jun 2011
    213
    no haldex i believe, dont think engines tend to give much trouble, audi doing recall on coil packs foc so get this done if it hasnt already and as you mentioned cambelt/water pump change is imperative and might as well do aux belt as well. manual gearbox all day long for me and clutch may need or have been done. maybe about £500 for belt etc not sure but audi offer fixed price on such work and as you say just the normal things associated with 100k on it. couldnt comment on roof but i had a 3.0 avant and bar a cam sensor it gave no trouble at all and never even used a drop of oil
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    A4's have Torsen diffs, sealed for life
    afcjay's Avatar
    Aug 2008
    426
    Quote Originally Posted by fourcircle View Post
    Thanks for the reply
    1k a piece! ill have a good look at them then lol
    Dont have access to vagcom im affraid
    Twin turbo would be nice lol
    afcjay's Avatar
    Aug 2008
    426
    Quote Originally Posted by jutlis 3.0 View Post
    is that right that the quattros are sealed units and dont need oil/filters? Handy if they are.
    ill check about the coilpacks and get them done if they havent alreay (save a good few quid)
    Ive read about the cambelt/water pump and it seems that the bumper/front has to be removed! £500 would be cheap considering wouldnt it? Id get the aux belt done at the same time like you say
    Id like to think like you say the engine being a 3.0l should be pretty bomb proof
    afcjay's Avatar
    Aug 2008
    426
    Is that right.No oil or filters to change on them then?
    Mar 2008
    Dorset
    13,856
    Quote Originally Posted by afcjay View Post
    There's no filter. You can change the oil, and people do, but Audi state there is no requirement to do so.
    afcjay's Avatar
    Aug 2008
    426
    ah right,thanks for that
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,323
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    love my 3.0 Avant, awesome engine and even better when mapped, as said, defo go for a manual i hate auto's, i wouldnt have it any other way
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    Mar 2009
    471
    Worth bearing in mind, only front wheel drive models have the cvt multitronic gearbox, the quattros have a conventional torque converter auto box which is very reliable.
    Roof is fairly problem free, obviously check operation a few times and check rear glass window isn't loose as can't be repaired apparently. new roof required.
    B6 S4 4.2L V8 Cabriolet Black Manual Quad Milltek Non Res
    Mar 2009
    471
    Also ensure the roof stowage box selector lever in the boot works correctly
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    Quote Originally Posted by paul26982 View Post
    really? I was told remapping a 3.0 would have limited benefits since it's naturally aspirated. did you have yours done?
    Jan 2011
    687
    As above check the rear window some early cabs had probs with the window bonding failing and the glass coming away from the fabric. It can't be repaired. You can pick up new roofs on eBay, I got a brand new black fabric outer for £150 woohoo as a spare.
    Heated seats are a must if you get full leather in my opinion.
    Check all the electrics work and cam belt, a proper belt including rollers tensioners and water pump will set you back about £800 inc vat at a dealer.
    Check the plenum chamber ,sticky is in here.
    I love my cab, best most fun car I ever had and this is about my 15th car
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
    Aug 2009
    north east U.K
    1,323
    yeah a friend of mine has transformed it, john at big fish tunning does his own custom maps, mid range its awesome aload of torque
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    damn. i'm guessing the round trip from finland plus map cost will work out more expensive than I can justify... hmmm
    Aug 2009
    north east U.K
    1,323
    Yeah does deals Think £200 or £250, cheapest about with a massive reputation etc, He just loves what he does
    afcjay's Avatar
    Aug 2008
    426
    Thanks for all the replys. Picked up a manual 3.0L Quattro Sport 53 plate,102k with FASH,12 months MOT,metalic black,full leather for a little over 4k so happy days (when lookiing on various sites they were asking stupid money).Will get some pics up in the near future as im sure she will want me to give it a bit of a detailing. Once again thanks for all the replys,shes over the moon with it
    Aug 2009
    north east U.K
    1,323
    the noise gets addictive, get pics up in this thread once sorted, Sounds like a convertible of mine
    afcjay's Avatar
    Aug 2008
    426
    will do.once again thanks for all the replys/help/advice
    Mar 2008
    Dorset
    13,856
    I didn't even know the 3.0 Cab's came with quattro!! I think they come fwd too?
    fourcircle's Avatar
    nj
    Aug 2008
    Kajaani, Finland
    846
    yep. both. I once followed a 3.0Q cabby on the M74 before I owned my A4 and I remember thinking "oooh. that thing looks torquey! I want one" ... but eneded up with an avant with having small kids and all
    Feb 2011
    Whipsnade UK
    94
    LOL I've had two very nice winters with my 3.0 Cab Quattro Tiptronic. And very nice it is indeed. Can't say (famous last words) anything has gone wrong with mine, other than a coil pack one day. Bought mine at 48k miles, now has 81k miles. Great cars.
    PS. Does a remap of the 3.0V6 really make a difference? I'm tempted if it does, and wishes my exhaust went to give it a little bit more sound as it is nice :0
    3.0V6 Quattro Convertible Tip - Crystal blue, blue roof, grey leather
    Upgrades: RS6 18" Wheels, Pirelli Zero Rosso 235/40R18, Philips extreme bulbs, brodit phone holder, Wind Deflector, BMC Air Filter
    May 2011
    136
    I've been talking to Will at p-torque and he seems to think a re map suits the V6 ! It makes the car alot more drivable .
    I had my old R32 mapped but had the dsg done as well so it was an all over change !
    I'll be getting mine done once I've got some other bits sorted !!
    Aug 2009
    north east U.K
    1,323
    trust me makes a hell of a difference, love mine
