Results 1 to 13 of 13
    Turkster's Avatar
    Bro.Paul 2.5TDI Quattro Sport
    Dec 2007
    2,723
    Changing an engine mount on a 2.5 TDI
    I'm about to attempt to change an engine mount on my 2.5tdi.
    After a quick inspection, I see that the mount itself is sat on a mounting bracket made from alloy.
    My question is : do you support the engine and lower the engine mount down on the bracket it sits on ?
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,450
    Turkster, have a look at the link below, just change at the top of the page for your model. It seems quite a useful sight i found. Hope its of some use. If not, sorry in advance.
    AudiDIY.com Audi B5 A4 DIY Articles
    Jul 2007
    London
    3,235
    Quote Originally Posted by Turkster View Post
    Yep, yo need an engine crane. be careful how you hook it though, i had one of the inlet manifolds snapped under strain from where you lift the engine !
    Another option is lowering the subframe and supporting the engine but it will require new bolts and geometry check if done that way !
    FOR SALE:
    Turkster's Avatar
    Dec 2007
    2,723
    Quote Originally Posted by adamss24 View Post
    I was looking at supporting the engine from under side ( big plank of wood spread out over the underside of the engine ) and then undoing the bracket that holds the mount, letting the engine mount to become free to drop out as a whole after the top screw was undone, that way the engine can stay put and the mount should be free to go ?
    Mar 2011
    Chester
    167
    I've got the 01375 fault code (the mount with the sensor). The bloke that does all my work suggested it's nothing to worry about but I can't help thinking that's probably because it sounds a right pain in the arse to do. It's probably not healthy to leave it as it is......if I did leave it wouldn't it put extra load on other components?
    A4 (B6) 2.5TDI QUATTRO SPORT AVANT
    Turkster's Avatar
    Dec 2007
    2,723
    im sure the 2.5TDI has 2 with wired sensors mate.
    my car seems to have a knock upon start up from that area of the car, my car has had the 01375 code since 2007 so maybe the fluids inside have drained away and caused the pressure on the centre bolt to snap,
    Mar 2011
    Chester
    167
    Righto. Cheers for that. It's in for a 6k oil change in a few weeks so will probably get it done then.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    ive got a brand new non wired engine mount if anyone requires one... 8EO 199 382 AG just to add i also had this code and it was the rear gearbox mounting completly split away causing excessive movement and the sensored mount was picking up the extra knocking...
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    Turkster's Avatar
    Dec 2007
    2,723
    Quote Originally Posted by marktdisport View Post
    Ah, did you get a knock at start up before you even moved the car ?
    Iv got 2 engine mounts from a 1.9TDI but i have a feeling they are not going to fit my car at all ?
    What enging is the engine mount you have for ?
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,267
    did mine last summer, As turkster says really. Start by removing anything that stops you getting to the top nut on the engine mount in question and then remove the top nut, its 10mm i think. Next Support engine on a trolly jack, i placed a steel spreader plate and then a plank of wood between the sump and jack. Then undid the alloy mounting bracket from below. remove and change the engine mount then refit the lot, i refitted the bracket in the same position as before removal, it has a bit of sideways movement so can go back on slightly off the mark. remember to refit the engine mount at the same rotation as it came off. bobs your uncle, All in it only took an hour, I think i could half that time on the next one.
    Its not the safest way to do the job as adamss24 says it should be done with a crane, however i had no issues at all and no need to borrow or hire a crane.
    Jul 2011
    mids
    1,193
    turkster i was getting a slight thud from the mount when pulling off but if i was moving slowly on slight downhill and released throttle i was getting a massive thud... felt by the o/s gearbox tunnel.... the mount i have should be for a 1.9tdi... what part numbers do you have.... need someone with ekta to check m8
    A4 TDI 130 SPORT..
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    1,267
    both the mounts are the wired type on the 2.5.
    Turkster's Avatar
    Dec 2007
    2,723
    just found this if it helps anyone
    Audi B6/B7 S4 DIY: Starter Replacement
  1. 2.5 v6 tdi engine mount swap
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2011, 21:47
  2. Changing top mount bushes/bearings
    By Plunky in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 17:38
  3. 2.0 TDI engine mount failure
    By pioneer181 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th February 2010, 15:27
  4. Advice on changing A4 TDi Fuel Filter(pd engine, 115hp)
    By impster in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th October 2009, 18:16
  5. Front Engine Mount (Dog-bone mount)
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th March 2006, 15:45
