    Mar 2012
    Audi A4 2007 Cabriolet - roof problems... help please!
    Hi,
    Basically, the roof on my 2007 a4 cabriolet failed to close this week. The roof opened fine with no problems, when returning home, stopped with the engine running on the driveway, pressed the buttom to put the roof up for the night. The windows went down about half way as they should, then the roof lid started to raise in order for the roof to come out and over the car but stopped about after moving only 5cm!
    After reading the manual, suggestions of leaving the motor for 30 ish mins to let the electric motor cool if overheated as i tried the roof switch several times. When rturning to the car to try again after 30 mins, the roof did exactly the same thing. The roof lid was not catching on anything because it was easy to lift the lid manually to see the roof in its compartment, but it had no mechanical support from the hydaulic arms either side that open the lid for the roof to come out as if i was to let go of the lid, it would simply yet slowly close shut just to about 5cm away from the body of the car.
    I had to manually lock and lift the roof closed in order to lock the car for the evening.
    Has anyone else had similar problems or situations? What might be the likely cause of the fault before it has to go to Audi for what I guess would be a costly fix...??
    Thanks for taking the time to read and I look forward to some replies.
    J
    bowen's Avatar
    Mar 2011
    456
    Is your drive way on an incline/decline?
    Do a manual rest and try it again. My roof plays up now and again, a reset usually works.
    There is a thread in the B7 section about replacing the motor.
    Audi A4 B7 SE S line TFSI Quattro.
    Mar 2012
    Thanks for your reply.
    The drive is flat/level, no incline or decline.
    I shall try a manual reset of the roof later on this evening and post my findings on here. Hoefully the reset shall work tho :-)
    Regards,
    J
    bowen's Avatar
    Mar 2011
    456
    9/10 a reset will work. The same thing happened with mine, try not to think the worst.
    Mar 2014
    Hi there,
    I have the exact same issue. How do you do a manual reset please?
    Thank you.
    Bob
    Jan 2011
    684
    Link to youtube video showing how - How to Manually Operate 2005 B6 Audi S4 Convertible Top - YouTube
    Be careful its a heavy bit of kit !
    2003 A4 Cab 2.4 V6 Manual / 43k miles genuine woohoo (on a 10 year old car lol) / Ebony Black Metallic / Full Grey Leather / Fully Electric Seats / Heated Seats / Interior Light Pack / Cruise / Wood / Bose Symphony II / Black roof
  1. 2010 Audi a5 cabriolet 2.0 Tdi S-Line roof repair
    By H8 in forum A5/S5/RS5 Forum
    Last Post: 21st November 2011, 21:48
  2. A4 CABRIOLET ROOF PROBLEMS, SOLVED
    By Paul,lithy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th October 2011, 18:05
  3. audi 80 cabriolet 1993 2.6 hydraulic fluid for roof
    By marvoman in forum Classic Audi Forum
    Last Post: 29th March 2011, 22:47
  4. 1996 Audi 80 Cabriolet - Roof Problems
    By stellarborne in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:30
  5. Audi Cabriolet roof problem
    By RoStar in forum Classic Audi Forum
    Last Post: 28th March 2004, 18:47
