My single cd Concert cd player is on it's way out so i decided to go for the SymphonyII tape and 6 Disc unit. Thought that the climate control panel would just slot in lower down as seen on other models so a bought one. then realised I need the cage with the different gaps, and then then i noticed the difference between the climate control panels not fitting low down due to the angle of the dashboard so got one of those.
It's off a B7 2007 A4, (goes on and on this does) after buying that thinking it was the same i read somewere about needing a small modification to get the heated rear screen to work. tested it and it works as it should apart from the heated screen, stays on for about 2 seconds. what do i need to do ? got everything i need for it now, i think
I'm considering trying swapping the front fascias over from one another
Wish I'd just bought another Concert now !
