JMB RetrofitsVolks Autos
Like Tree3Likes
  • 1 Post By jimmcgee
  • 1 Post By Andi25th
  • 1 Post By L7AUDI
Thread: Boost gauge now fitted.
    bowen's Avatar
    Mar 2011
    456
    Ok, so I finally got around to fitting my boost gauge! My next question is what bar pressure should it be running? (wish I had bought a psi boost gauge)
    Its standard 1.8t map.
    Audi A4 B7 SE S line TFSI Quattro.
    Dec 2011
    149
    1bar = 14 psi so should be just under 1 bar
    bowen likes this.
    bowen's Avatar
    Mar 2011
    456
    Bare with me whilst i pick your brain a little more; when driving for example in 5th gear (flat out) the gauge shoots to 1bar then drops slightly under.
    Im guessing thats correct going by your reply?
    Andi25th's Avatar
    May 2010
    Inverness
    226
    It should peak then drop aprox 2-4 psi. Then tail off as the revs go up.
    bowen likes this.
    bowen's Avatar
    Mar 2011
    456
    Thought as much.
    I have a suspect boost leak, which is why i wanted to double check.
    thanks,
    L7AUDI's Avatar
    Feb 2012
    Cornwall
    82
    I had a boost gauge once it was very pretty to look at but in reality when spanking it the car was so quick I really didn't have time to look at it haha
    bowen likes this.
    54' 1.9tdi A4 Avant quattro sport - pretty much fully loaded
  1. Fitted my boost gauge
    By S3 ABV in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th September 2009, 12:43
  2. AWE Boost Gauge Fitted
    By norad97 in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2008, 18:40
  3. APR Boost Gauge Fitted!
    By mattfinn in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th March 2008, 17:16
  4. Boost gauge fitted
    By danotto in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th February 2008, 18:35
  5. APR Boost Gauge Fitted
    By welshdragon in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th October 2004, 08:22
