Monster MotorsportEM Tuning
    Mar 2012
    19
    Changing Front Discs 2003 Avant 2.5tdi
    Hello
    We had a reported problem on out MOT that the front discs would need changing soon. I have done a lot of work on older cars I just wondered how easy it is to do and are there any specail tools required
    Terry
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    Dead easy, undo 2 caliper bolts and remove and then take the carrier off ( 2 bolts) turn the steering wheel so that you can get some purchase with your breaker bar on the bolts. the rest is to swap over the disk and push back the caliper piston. you can use a clamp for the fronts if you dont have a rewind tool as the piston does not have to be rotated like the rears. Its good practice to cover the rear of the pad in copper grease and i always put some red rubber grease under the caliper slide rubber also and i always give the whole assembly a good wire brushing and a clean up.reassemble and your good to go. It helps to remove the cover from your brake fluid tank also while you do the job but place a rag around to stop any excess overtopping.
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,483
    Terry, have a look at this thread.
    DIY Guides + FAQ & B6 Wiki
    Mar 2012
    19
    Thanks so much, I will order the discs!!
    Terry
  1. Newbie questions on 2003 2.5tdi Avant
    By terryp in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th March 2012, 19:55
  2. 2003/53 Audi 2.5TDi Quattro Sport Avant
    By JohnboyC in forum For Sale/Wanted - Audi Cars
    Last Post: 17th November 2011, 13:42
  3. 2003 A4 Avant 2.5TDI Quattro Gearbox problems
    By Colday in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th September 2011, 15:29
  4. Changing Rear Discs and Pads A4 2003 Conv
    By Audi-A4-Conv-2003 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd January 2010, 16:14
  5. HELP: Changing a headlight bulb A6 Avant 2003
    By SixAvant in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 27th July 2007, 11:53
