JMB RetrofitsBadger5
Results 1 to 15 of 15
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    646
    Any thoughts on this problem?
    About 1.5-2months ago I changed my thermostat. Lost a few litres of coolant. Topped back up, drove for a few weeks no problem. Then got a coolant warning light. I pull over and check and the reservoir is empty. Top it up, no foamy stuff in oil filler cap, go on driving. Put cardboard under the car overnight - no drips/leaks, no foamy stuff in oil. All seems well.
    Today, I start up and go 1/2 a mile and the coolant light comes on again. I pull over, reservoir is empty again - no problems in oil, I top it up and all appears fine. No leaks (put cardboard down all day).
    Anyone have any thoughts on what could be causing this? I don't really have any experience in looking for leaks. All I can think is it's a failing reservoir cap or a small crack in the reservoir bottle (perhaps?)
    If it's relevant, I had the water pump changed 2 months ago (when the cam belt was done)
    Any ideas appreciated!
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    just about, right here!
    3,756
    have you checked for leaks behind your heater matrix under dash?
    this can be a usual suspect!
    look for damp carpet under dash area towards centre console!
    also does your heating get very hot as before or is it lacking heat?
    lacking heat, possible leak mate
    simon.m's Avatar
    Oct 2009
    2,746
    do you have steam like smoke coming out of the rear also one more way to check the head gasket has not gone is if you let the car get to 90c put the heater on high and full heat if it stays hot and dose not cool it should rule that out say this as my last car did this and it was only when i had it looked at they told me how to look for it also the top rad pip will get hard and look like it will pop not to scare you but just to rule it out mate
    benjie's Avatar
    Oct 2009
    646
    OK, thanks, I'll check that out. I think the heating is behaving normally - I usually leave it off until the car has fully warmed up and I'm driving at a constant speed before I put it on and I haven't noticed it being less warm than usual. I'd best have a lok at getting access to this matrix so that I can make a visual inspection too. I remember on here a thread called something like "how to get at the heater matrix - the easy way" or something like that. I'll have a look. Thanks.
    benjie's Avatar
    Oct 2009
    646
    Simon - thanks, all noted. I'm driving for 1hr tomorrow so will check when I get to my destination. Just to clarify - if I turn hating on MAX and it stays hot and doesn't eventually cool a bit, then it's a possibility the head is on its way out? Is that right?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,526
    it could be a nackerd cap
    thats where my water was going
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,756
    mmm, possibly!
    lots of even heat rules out your heater matrix, keep an eye on your temp guage and if poss check firmness of coolant pipes mid journey if possible!
    like simon stated, these might go rock hard and possibly split, pop or explode! if so release pressure SLOWLY from your header tank in order not to scald yourself and lose coolant!
    take a 2litre bottle of water with you for emergencies! just in case dude!
    CHEZ's Avatar
    moderately amusing
    Jul 2011
    3,756
    very good viable point!
    simon.m's Avatar
    Oct 2009
    2,746
    no mate if it stays hot it is ok its if it cools off then its posbly the head going i reall yhad no idea mine was going all i see was loss of water hd no idea where it was going car run fine but 20min run would empty the tank mine was like it for 2plus mths till it then started to get wores really hope its not that mate
    Oct 2009
    Hull
    1,442
    I had this same problem after a stat change when I put it all back together the seal moved causing a very slight leak when hot and it stops when it cools it never left any fluid on the floor as it sits on the mount that's right below it
    New seal will see you right
    benjie's Avatar
    Oct 2009
    646
    Right - just been out. Level hasn't changed.
    Top/bottom rad pipes very squishy, nothing brittle about them.
    Reservoir lid - it's not hard to undo/do up, perhaps not creating a seal.
    Thermostat - there is some staining around it. I did give the area a rinse after I changed the stat, but some coolant may have remained there, so will check that after the drive tomorrow.
    Here's my coolant... it's nearly 2 yrs old so will be changing it soon, but does it look a bit dodgy coloured?
    Lancaster
    1,788
    Does it smell at all? I'm sure I've heard of gearbox oil coolers popping on these and filling the box with water. Coudl well be wrong though.
    To do: None yet.
    marktdisport's Avatar
    Jul 2011
    mids
    1,193
    id be looking at the thermostat housing if it didnt leak before you messed why look elsewere first........ you may find when the cars parked after a run the water evaporates with the engine heat before leaking on the floor until the pressure as drained from the system.... get it pressure checked and watch the thermostat joint you probably nipped the thermostat o ring and be a simple cheap fix
    A4 TDI 130 SPORT..
    now sold but still in the family, gone back in time to the cupra R again..
    beachbuggy's Avatar
    Surrey
    1,745
    Sometimes when you loose coolant such as in replacing thermostats you can end up with an airlock / block in the system. So you fill it up to top the coolant up and the block remains, Alls well. Then one day block gets moved and coolant takes up the space and so on until level is restored . Ive seen it on the a4 before and happened on mine. Took nearly an extra litre on coolant to top up and stay topped up and been gone since. I'd suggest you top up the coolant and hope its that.
    benjie's Avatar
    Oct 2009
    646
    Thanks everyone for your helpful input. I'm now 95% sure it's the stat housing, looked earlier and saw some liquid under it... incidentally, the golden time seems to be 4 hours... still enough pressure to push the coolant out, not enough heat in the block to evaporate it!
    Will check how tight the bolts holding the housing on are tomorrow and will probably change the O ring to be sure.
    Thanks!
  1. Your thoughts...
    By ross_broughton in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st June 2010, 22:36
  2. Your thoughts on this
    By m444ty p in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2009, 18:03
  3. Thoughts welcome ?
    By crypric23 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th August 2009, 13:33
