Do you not have to raise the expansion tank like on the b5, 4 to 6 inches higher then the water should be higher than the heater matrix level, then undo the pipe with the hole in on a b5 its the left pipe looking at the bulkhead just pull it back a little until water starts to come out when the air has gone push back on the put the cap on the expansion tank then put it back into the normal position should all be ok
