EM TuningMonster Motorsport
    Mar 2012
    Unhappy Help! Audi 3.0 V6 Quattro Sport Auto 2001 advice please!!!
    Please Help! I need some advice please on the reliabilityand quality of an A4 3.0 Sport Quattro Auto as I am looking at buying one which is a 2001 51 with 92000 miles, The car is going to need a cambelt and waterpump which All Audi Specialists Bristol have quoted £710 to do so I just want to make sure I don't buy something that will let me down once I have pumped all that money into it as unfortunately my pride and joy A4 2004 1.8T 190 Sport CVT with only 80k has been a real friday car and now the CVT gearbox has failed me.
    Any advice would be much appreciated...
    Thanks,
    Alex
    Nov 2011
    Exeter
    Hi
    I have the same car on a 2002 51 plate with 86,000 miles. Cambelt and waterpump was done just before I purchased the car. You should be able to save £200-250 if you go to a good independent but use oem parts. Get them to check tensioners and pulleys as well when the front is off. Gearbox is tiptronic and not as fragile as CVT.
    If possible get the car scanned before purchase as this will indicate any issues, also check all electrical items work.
    I am very pleased with my car once I got used to the fuel consumption !
    Regards
    Mark
    Woorlord's Avatar
    shifting to Hyperspace... .
    Dec 2007
    Tiptree, Essex
    946
    Also change the thermostat at the same time as water pump and cambelt.
    Surprised Audi can't do it for a similar or cheaper price than that indy you've been quoted.
    My local Audi dealer was around £500 a couple years back so expect a little increase - bargained with them to get it down to the same as a 4-cylinder engine timing belt change.
    Check with an Audi dealer that the car has had the ignition coils replaced under the recall of around a year ago also - Workshop Campaign 28E9.
    (Would normally be around 6x £38 just for parts.)
    2001 A4 Saloon 3.0 Quattro Sport Tiptronic - Platinum Leather/Heated Front Seats/BOSE/DIS/Cruise Control
    Retrofits:GmBH Bumpers, F&R Ambient LEDS, OEM Valeo Xenons (D2S) & Headlight Washers, Auto-dipping RVM, Footwell Lights, Vent Control illumination, ISO-Fix, RNS-E & OEM Bluetooth + VIMhack + Video i-pod & Aux inputs, Rear PDC, Powerflow 100mm Tips, Reversing Camera
    2012 A4 Saloon 2.0 TDIe Technik (163ps)
    Diagnostics:VCDS HEX+USB+CAN Cable
  1. Replies: 0
    Last Post: 2nd January 2012, 12:20
  2. audi 1.8 t 2001 quattro buying advice
    By ash_gtg4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd October 2011, 09:56
  3. Replies: 0
    Last Post: 26th September 2011, 19:50
  4. 2001 Audi A4 3.0 quattro Sport auto tip
    By imported_ashs3 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th June 2005, 18:24
  5. 2001 Audi A4 3.0 quattro Sport auto tip
    By imported_ashs3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th June 2005, 09:35
