Monster MotorsportVolks Autos
Results 1 to 13 of 13
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Question Engine Management fuses 29, 32, 34, and 43 (A4 Avant 1.9 TDI 130)
    Does anybody know which aspects of engine management each one is linked to? It just say "engine management" in the handbook and on the fuse box list......
    29:
    32:
    34:
    43:
    *WANTED* AUDI CD PLAYER
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    If anybody has a 130 TDI, I would really appreciate it if you could pop out and see what fuses you have in the above four locations
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Can anyone answer either of the above?
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I'll look tomorrow, mines a 2.5 though.
    Failing that Etka/Elsa might help.
    Aug 2010
    1,540
    i've wrote them down, if i remember i'll have a look at work.
    what year is the car?
    what fault are you chasing?
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Thanks for the help James/Murran.
    There is no fault I hope. None of these fuses are present in my car (51 plate), hopefully they are engine management fuses on the petrol models.
    Aug 2010
    1,540
    i looked but non of the ones you listed corresponded to a avf awx (130) engine.
    what is it you wanted to know???
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Superb, thank you.
    My concern was that my fusebox was missing the four fuses listed above, and all relate to engine management (as according to the handbook). I assumed that at least one of them would be in use on the 130 TDI, but it seems not!
    Does my B6 have the AWX engine?
    Mar 2008
    Dorset
    13,856
    Engine code should be on your data sticker.
    Spare wheel well/service book etc.
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Just had a look and it's clear as day in the service book - AWX (cheers James)
    Aug 2010
    1,540
    i had a look. non of those fuses listed are for the engine management on an awx engined a4.
    i did write down which ones are and what systems they "protect" but, being a dosey coont, ive left it at work.
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Good stuff, thanks Murran
    Dec 2011
    Blackburn, Lancs
    21
    Evening all,
    Wee tad weird, I've seen some A4 diesels with an engine management light & some without (prior to starting the engine), considering they're all B6's, why is this? I'm confused, I thought mine had been tampered with, so I took out the cluster, pulled it apart, all LED's including the engine management LED, were fine. The reason why I'm mentioning this is I've done a full VAG COM scan, no faults. But a couple months ago I had a faulty N75 Solenoid valve, but EML the Light did not light up once (only limp mode). Any insight would be very helpful, me thinks it's CAN related (I don't have CAN-2002)
    Quote Originally Posted by murran View Post
  1. 2.0 TDi Engine management light help
    By Jonny84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th November 2010, 16:32
  2. 2001 tdi engine management light.
    By deanski in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th August 2010, 21:55
  3. A6 1.9 TDI engine management ? - diagnostic codes
    By oxford_hippo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th May 2010, 23:15
  4. A6 1.9 TDI engine management problem?
    Last Post: 4th March 2010, 09:58
  5. Replies: 12
    Last Post: 14th November 2006, 13:42
