EM TuningAH Fabrications
Results 1 to 8 of 8
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,317
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    Coming Home lights
    Anyone tried this way on there B6.
    cominghomelights - Audi Retrofit
    ive read that you can do it by changing the switch etc, but this way seems so much easier.
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    Alan H's Avatar
    Need a V8 or Bi-Turbo.......
    Aug 2010
    Dudley, West Midlands
    453
    That looks like a good retrofit. I would really like that function mine.
    Are you going to attempt it?
    Take some pics if you do!!
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,149
    Not sure, but I would expect the wiring to be different on the B6 A4 compared to the 8P A3.
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    636
    It's not something to be enabled on the B6 like it is on the A3 8P. I have retrofitted it along with an auto-dimming interior mirror, wing mirrors and auto headlights. Quite complicated, but not hard. The auto-dimming mirror is needed to tell the coming home lights when to turn on.
    From that write up, I would imagine the coming home lights would come on whether it was light or dark - fine if that's what you're looking for, but will look to others like it's not working properly. Also, to follow that A3 thread, you would need to find out exactly what wires you are removing/replacing so as to do the same on the B6.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    Point_Audi's Avatar
    Vorsprung durch Technik
    May 2010
    Ireland
    574
    I would certainly be interested in this mod myself. I had a look around the net and found this link http://bigskyeuro.com/images/gallery...H_retrofit.pdf Not sure if it would be helpful at all!
    A4 B8 2.0TDI S-Line Executive
    Events Moderator
    Ireland/Northern Ireland
    Alan H's Avatar
    Aug 2010
    453
    Quote Originally Posted by point_audi View Post
    Interesting. Another take on the same idea....
    benjie's Avatar
    Oct 2009
    636
    From memory, that looks like the wiring I used in mine, an F module is £230+VAT from a dealer and once you enable it, you will have a permanent yellow warning light in your dash (where the miles to empty/mpg is) that looks similar to the symbol on the new switch shown in the pdf guide.
    27,075
    It was done on a B6 cab sometime back, problem is the lights are on during the day aswell, as no sensor to distinguish between the different light conditions, so expect some quirks for sure, not really a substitute for the complete system, installed a fair few proper systems & its great with auto lights etc.
  1. Coming Home & Leaving Home Lights Enabled
    By MarcQuinlivan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2 Days Ago, 08:27
  2. Coming home and Leaving home lights - VCDS trouble
    By Pricy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd June 2011, 10:07
  3. Behaviour of coming home / leaving home lights
    By cooni in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2010, 13:22
  4. Vag Com Faults after Coming Home & Leaving Home Lights Enabled .
    By Digzz in forum VCDS (formerly VAG-COM) forum
    Last Post: 3rd February 2010, 14:45
  5. Coming home/leaving home lights
    By S3-Andy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2010, 13:30
