Badger5JMB Retrofits
Results 1 to 18 of 18
    S3 GAZ's Avatar
    Dec 2006
    East Ayrshire Scotland
    343
    Major electrical woes.
    Car is 2004 1.9tdi Quattro sport 130bhp.
    i was driving along today when the yellow traction control triangle appeared on the dash, car was driving fine so thought il scan it when i get home. Got to a junction and went to indicate but nothing happened. interior lights started flashing, hazard triangle started to flicker and nothing worked
    no window wipers or washer jets
    no headlights,
    no indicators
    no electric windows
    no central locking.
    when i pressed brake there was a clicking sound also but brake lights worked.
    some things still function properly like sidelights, rns-e/radio, dis, all dials work ok.
    odd thing is when i removed key from ignition the dash stays illuminated and the rns-e stays on.
    i have run a scan but has not revealed anything.
    i am thinking convenience module. passenger footwell is bone dry as i have removed drain plugs in battery tray.
    any ideas
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    Any water leaks around the ECU box?
    S3 GAZ's Avatar
    Dec 2006
    343
    had a look but all seems fine at ecu. is there a electrical control unit. lots of clicking coming from behind steering wheel whist hazard triangle is simultaneously flickering,
    Mar 2008
    Dorset
    13,856
    And nothing on a genuine VCDS scan? Odd.
    Lancaster
    1,780
    How does it start in cold weather?
    To do: None yet.
    S3 GAZ's Avatar
    Dec 2006
    343
    Quote Originally Posted by BlackQuat View Post
    Meant to say Car is 2004 1.9tdi Quattro sport 130bhp
    Funnily enough its stars like a dog in cold damp mornings. I have posted in the thread relating to this about the grey smoke on startup that quickly dissapears as soon as the car has been running for a few mins. Is there a connection between the electrical issues and poor starting.
    Re Quattrojames it was a vcds lite scan not genuine cable so can't rely on it to be honest. Il get it scanned properly ASAP.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,155
    May be an idea to check all earth points.
    I would expect there to be an earth point behind the dash/foot-well, may be worth taking them off, rubbing down slightly and re-installing - do the same for the "-" connection on the battery also.
    I had similar issues on my Ibiza Cupra, however it threw up a lot of fault codes - turned out it was an earth point for the ECU.
    S3 GAZ's Avatar
    Dec 2006
    343
    Quote Originally Posted by AlexGSi2000 View Post
    Thanks Alex. Il check all earth points.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    Sorry this maybe a bit vague but ive read before about a power distibution module they can cause all sorts of electrical issues when they go, sure its behind the dash area aswell
    S3 GAZ's Avatar
    Dec 2006
    343
    Well went out this afternoon after not touching the car since last night and all the electrics are working perfectly. None of the symptoms I encountered yesterday have reappeared.
    I took the car out for about 40mins and the electrics were spot on. I wonder if it's had one of those 24hr bugs that make u phone in sick
    Bloody electrics do my nut in. I'm sure it won't be the last I have trouble with them but fingers crossed it was a little gremlin that's rectified of its own accord.
    Thanks for help guys.
    Feb 2012
    Liverpool
    1,155
    Ah thats good news - could have been damp somwhere....
    Lancaster
    1,780
    I'm pointing towards the battery.
    To do: None yet.
    S3 GAZ's Avatar
    Dec 2006
    343
    Thinking that myself mate. It was replaced just before I bought the car. It's an RAC branded one don't know how they are.
    Is that why you were asking about the cold starts
    I'm running a fair bit of kit in it. Rnse and head mounted DVD player for my bambino which was incidentally playing the smurffs at the time. Maybe too much juice required and battery is on its last legs.
    Jan 2014
    Highlands Scotland
    86
    im having the exact same problems you have but mine haven't dissapered lol did you find out what it was in the end ?
    S3 GAZ's Avatar
    Dec 2006
    343
    Just been reading your thread mate. Its never returned in that guise.
    I have since had some electrical starting issues caused by water in the ECU box that corroded some wiring and flung up all manner of dash lights
    Jan 2014
    Highlands Scotland
    86
    cheers for the reply man il need to check the box out the morro lift the carpets up aswell make sure there dry underneath its raining pretty heavy right now so will no in the morning if waters getting in somwhere haha
    S3 GAZ's Avatar
    Dec 2006
    343
    Have you checked your battery. When its a bit low on charge it will put the dash lights on ABS, BRAKE etc
    Feb 2012
    Glasgow
    228
    I had this problem before christmas and it turned out moisture had gotten into one of the control modules under the dashboard (lower right behind steering wheel) it was a replacement job for me unfortunately
  1. Major pi**ed
    By goodwoodgreens3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2011, 23:27
  2. Sudden random major electrical woes
    By voteforpedro in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th February 2009, 09:52
  3. Major Problem Please help!
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2007, 17:25
  4. Major problem with my S3 -
    By willow in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th November 2006, 13:03
  5. Help: Major S3 problem
    By dpeilow in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2006, 13:42
