Major electrical woes.
S3 GAZ
East Ayrshire Scotland
Car is 2004 1.9tdi Quattro sport 130bhp.
i was driving along today when the yellow traction control triangle appeared on the dash, car was driving fine so thought il scan it when i get home. Got to a junction and went to indicate but nothing happened. interior lights started flashing, hazard triangle started to flicker and nothing worked
no window wipers or washer jets
no headlights,
no indicators
no electric windows
no central locking.
when i pressed brake there was a clicking sound also but brake lights worked.
some things still function properly like sidelights, rns-e/radio, dis, all dials work ok.
odd thing is when i removed key from ignition the dash stays illuminated and the rns-e stays on.
i have run a scan but has not revealed anything.
i am thinking convenience module. passenger footwell is bone dry as i have removed drain plugs in battery tray.
any ideas :(
had a look but all seems fine at ecu. is there a electrical control unit. lots of clicking coming from behind steering wheel whist hazard triangle is simultaneously flickering,
How does it start in cold weather?
Meant to say Car is 2004 1.9tdi Quattro sport 130bhp
Funnily enough its stars like a dog in cold damp mornings. I have posted in the thread relating to this about the grey smoke on startup that quickly dissapears as soon as the car has been running for a few mins. Is there a connection between the electrical issues and poor starting.
Re Quattrojames it was a vcds lite scan not genuine cable so can't rely on it to be honest. Il get it scanned properly ASAP.
May be an idea to check all earth points.
I would expect there to be an earth point behind the dash/foot-well, may be worth taking them off, rubbing down slightly and re-installing - do the same for the "-" connection on the battery also.
I had similar issues on my Ibiza Cupra, however it threw up a lot of fault codes - turned out it was an earth point for the ECU.
Thanks Alex. Il check all earth points.
Sorry this maybe a bit vague but ive read before about a power distibution module they can cause all sorts of electrical issues when they go, sure its behind the dash area aswell
Well went out this afternoon after not touching the car since last night and all the electrics are working perfectly. None of the symptoms I encountered yesterday have reappeared.
I took the car out for about 40mins and the electrics were spot on. I wonder if it's had one of those 24hr bugs that make u phone in sick ;)
****** electrics do my nut in. I'm sure it won't be the last I have trouble with them but fingers crossed it was a little gremlin that's rectified of its own accord.
Thanks for help guys.
Ah thats good news - could have been damp somwhere....
I'm pointing towards the battery.
Thinking that myself mate. It was replaced just before I bought the car. It's an RAC branded one don't know how they are.
Is that why you were asking about the cold starts
I'm running a fair bit of kit in it. Rnse and head mounted DVD player for my bambino which was incidentally playing the smurffs at the time. Maybe too much juice required and battery is on its last legs.
im having the exact same problems you have but mine haven't dissapered lol did you find out what it was in the end ?
Just been reading your thread mate. Its never returned in that guise.
I have since had some electrical starting issues caused by water in the ECU box that corroded some wiring and flung up all manner of dash lights
cheers for the reply man il need to check the box out the morro lift the carpets up aswell make sure there dry underneath its raining pretty heavy right now so will no in the morning if waters getting in somwhere haha
I had this problem before christmas and it turned out moisture had gotten into one of the control modules under the dashboard (lower right behind steering wheel) it was a replacement job for me unfortunately
624
19
6K
6
951
844
