EM TuningMonster Motorsport
Results 1 to 21 of 21
    Mar 2012
    29
    Starts and Stalls Immobilizer flashing
    Hello everyone, the immobilizer is flashing on my car. Everytime I start the car it runs for a second and instantly dies.
    My friend was able to retrieve the errors.
    Does anyone know if the problem is related to Instrument cluster or ECU?
    By the way it is a 2002 Audi A4 3.0liter V6 Quattro.
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 008 - Implausible Signal
    Readiness: 0110 1101
    Address 02: Auto Trans Labels: 01V-927-156.lbl
    Part No: 8E0 927 156 Q
    Component: AG5 01V 3.0l5V USA 1213
    Coding: 0001002
    Shop #: WSC 05141 444 59564
    VCID: 3C7C36AE4031B1FC
    2 Faults Found
    18265 - Load Signal: Error Message from ECU
    P1857 - 003 - Mechanical Failure - Intermittent
    18258 - Powertrain Data Bus: Missing Message from ECU
    P1850 - 003 - Mechanical Failure - Intermittent
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Part No: 8E0 614 517 A
    Component: ABS/ESP allrad 1726
    Coding: 04497
    Shop #: WSC 06435
    VCID: 2648F4C6AEBD1B2C
    1 Fault Found
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    Address 08: Auto HVAC Labels: 8E0-820-043.lbl
    Part No: 8E0 820 043 AH
    Component: A4 Klimaautomat 1424
    Coding: 00000
    Shop #: WSC 00000
    VCID: 67D6B9C26937C224
    14 Faults Found
    00710 - Defroster Flap Positioning Motor (V107)
    41-10 - Blocked or No Voltage - Intermittent
    01809 - Actuating Motor for Temperature Flap; Left (V158)
    01810 - Actuating Motor for Temperature Flap; Right (V159)
    01274 - Air Flow Flap Positioning Motor (V71)
    00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
    30-10 - Open or Short to Plus - Intermittent
    00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
    00819 - High Pressure Sensor (G65)
    07-10 - Signal too Low - Intermittent
    00532 - Supply Voltage B+
    52-10 - Supply Voltage Too High - Intermittent
    53-10 - Supply Voltage Too Low - Intermittent
    01317 - Control Module in Instrument Cluster (J285)
    49-10 - No Communications - Intermittent
    01206 - Signal for Duration of Ignition Off Time
    27-00 - Implausible Signal
    00474 - Control Module for Immobilizer
    01794 - Control Module - Incorrect Chassis (VIN) Number
    35-00 - -
    27-10 - Implausible Signal - Intermittent
    Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl
    Part No: 8E0 907 279 E
    Component: int. Lastmodul RDW 0305
    Coding: 00001
    Shop #: WSC 00000
    VCID: 346C1E8E686179BC
    4 Faults Found
    01518 - Bulb for Back-Up Lights; Left (M16)
    57-00 - Electric Circuit Failure
    00988 - Lamp for Brake Light; Right (M10)
    01493 - Bulb for Blinkers; Front Left (M5)
    35-00 - -
    Address 16: Steering wheel Labels: 8E0-953-549.lbl
    Part No: 8E0 953 549 L
    Component: Lenksáulenmodul 0308
    Coding: 01141
    Shop #: WSC 00000
    3 Faults Found
    127-10 - Unknown Error Elaboration - Intermittent
    35-00 - -
    Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
    Part No: 8E0 920 950 H
    Component: KOMBI+WEGFAHRS. RB4 D25
    Coding: 03243
    Shop #: WSC 43169
    VCID: 2E580CE6864D536C
    WAULT68E52A142099 AUZ6Z0A0251508
    4 Faults Found
    01039 - Coolant Temperature Sensor (G2)
    01177 - Engine Control Unit
    65-10 - Unauthorized - Intermittent
    01312 - Powertrain Data Bus
    37-10 - Faulty - Intermittent
    01304 - Radio
    Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
    Part No: 8E0 959 760
    Component: Sitzmemory R2 F 0203
    Coding: 00002
    Shop #: WSC 63351
    VCID: F1E2579AD7F38C94
    7 Faults Found
    00668 - Supply Voltage Terminal 30
    06-10 - Signal too High - Intermittent
    01336 - Data Bus for Comfort System
    01330 - Central Control Module for Central Convenience (J393)
    79-00 - Please Check Fault Codes
    35-00 - -
    01446 - Sensor for Driver Seat; Seatback Adjust (G230)
    20-00 - Malfunction in Basic Setting
    Address 37: Navigation Labels: Redir Fail!
    Part No: 4B0 919 887 E
    Component: BNS 4.2 H05 BNO 0008
    VCID: 356A238A631B60B4
    3 Faults Found
    00625 - Vehicle Speed Signal
    03-00 - No Signal
    65535 - Internal Control Module Memory Error
    00-00 - -
    Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
    Part No: 8E0 959 433 T
    Component: Komfortgerát T5B 0617
    Coding: 28220
    Shop #: WSC 05141
    VCID: 4280485622D5C70C
    Part No: 8E1959801
    Component: Tõrsteuer.FS BRM 0002
    Part No: 8E1959802E
    Component: Tõrsteuer.BF BRM 0002
    Part No: 8E0959801A
    Component: Tõrsteuer.HL BRM 0002
    Part No: 8E0959802A
    Component: Tõrsteuer.HR BRM 0002
    19 Faults Found
    01333 - Door Control Module; Rear Left (J388)
    01581 - Incorrect Component Detected
    35-00 - -
    01134 - Alarm Horn (H12)
    28-10 - Short to Plus - Intermittent
    29-00 - Short to Ground
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Alarm triggered by Hood Switch
    35-00 - -
    01374 - Alarm triggered by Terminal 15
    35-00 - -
    01371 - Alarm triggered by Door Contact Switch; Driver's Side
    35-00 - -
    01331 - Door Control Module; Driver Side (J386)
    01332 - Door Control Module; Passenger Side (J387)
    01803 - Door Warning Lamp; Rear Left (W37)
    57-10 - Electric Circuit Failure - Intermittent
    01561 - Left Rear Door
    59-10 - Can't Unlock - Intermittent
    01334 - Door Control Module; Rear Right (J389)
    01562 - Right Rear Door
    59-00 - Can't Unlock
    Address 56: Radio Labels: 8E0-035-1xx-56.lbl
    Part No: 8E0 035 195 A
    Component: symphony II NP2 0050
    Coding: 00211
    Shop #: WSC 00000
    VCID: 254AF3CAD3BB1034
    5 Faults Found
    00858 - Connection; Radio ZF Output to Antenna Amplifier
    36-00 - Open Circuit
    00466 - Control Module for Steering Column Electronics (J527)
    01300 - Control Module for Navigation with CD-Rom (J401)
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    Wow - quite a list there!
    Sometimes when lots of faults show up it can turn out to be a bad earth - check all fuses and earth points.
    In regards to the cutting out it is the immobiliser - the key has probably lost its coding to the car.
    This link may help;
    eBay.co.uk Guides - How To Program Reprogram Your Audi Remote Key Fob - A4
    Oct 2009
    Hull
    1,440
    I've had this before although it was intermittent just once every 2 weeks or so
    I changed the batteries in the fob and its been fine since which is really odd as the chip doesn't use the battery! So no help really!
    27,097
    Thats a shed load of errors tbh whic stands to reason a power problem.
    Have a look at the battery treminals & grounding point to the chassis, see if its corroded.
    Yes its the immo blocking the start, what people need to realise is, on most cars, immo & remote lock systems are completely independent from eachother, so the guide above will not fix the issue at all, thats purely a guide for the remote locking side of things.
    I suspect the power issues that may be present are causing the immo problems aswell.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    the key reader may have packed in or the wire joining the keyreader
    iv had that a few times
    Mar 2012
    29
    Thanks for the input guys. I purchased this car from a private seller. The relays under the ECU were burned out. I replaced them and was able to start the car. The immo light has been flashing since I bought it.
    I checked all of the fuses (on the driver side panel) and they are fine.
    I found an aftermarket fob I believe under the seat. I am not sure if it is related to immobiliser or not. The battery inside is corroded. I will try replacing both batteries.
    Does anybody know how can I access the key reader wires? Is it a common problem on B6 A4's?
    bez101's Avatar
    Jul 2008
    8,491
    god knows what that remore is for
    prob from a diffrent car
    if car starts it wont be the wire from key reader id clear all the codes and rescan see what it comes back up with
    Mar 2012
    29
    I pulled the instrument cluster and found this.
    The cluster is obviously not original.
    My car was manufactured in 05/02
    How come the cluster was made in 05/01 ??
    Mar 2012
    29
    We tried and cleared the codes, but every time we scan it the same codes pop up.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,269
    if that is not the original cluster then it will cause a whole host of issues as a lot of the electronics specific to your car and ecu etc are contained in the cluster microchips. As far as i know most things communicate to the cluster to get an ok to work properly, A new cluster has to be coded in properly using vag-com. It maybe the cluster was swapped trying to fix previous problems by someone not really in the know.
    I would contact the number on the sticker first and get them to check why they have a sticker onyour cluster and what they did
    Mar 2012
    29
    Quote Originally Posted by swarcup View Post
    I contacted them and they are junk yard.
    The previous owner was having problems with dead pixels therefore he bought a used one.
    Can I pull the SKC code via VAG Commander 5.5?
    Or do I have to take the car to the dealer? Is there a way to disable the immo? I contacted APR and other tuners they say that they can't do an immo defeat on 3.0liter engines, only 1.8T.
    I don't care about the alarm or immo feature, I just want the car to run.
    Mar 2012
    29
    Went to the dealer, spoke with the SA, he told me that in the past they have had problems regprogramming used clusters because the clusters that were installed didn't match the options that the car had. They want $330 for reprogramming the cluster, because it is labor intensive for their technicians...and He also mentioned that they may not be able reprogram it...It all depends on the cluster.
    Part number of the cluster that my car had is 8E0-920-980-KX. My price is $920 plus they want my core return.
    If there is a way to kill the immobiliser please let me know, I am so sick of this car.
    bez101's Avatar
    Jul 2008
    8,491
    you can have the immo wrote out not sure if anyone does it in the usa tho
    27,097
    IMHO I dont believe what they're telling you, if its the same cluster part number or superceded, then tbh it should code up perfectly normal with just the mileage needing corrected externally, as options are coded afterwards when the cluster is coded to the immo, I mean you couldnt makeup this BS IMHO.
    330 bucks for potentially coding an cluster seems excessive, its a 10-20 minute job with road test of 10-20 minutes, so hows that labour intensive, as its just literally unbolt the trim or cluster, then lift out, swap over & code, bolt in & test, its an easy job with, if they know there beans an hour at most charge.
    Mar 2012
    29
    Any thoughts on how to disable the Immo?
    Mar 2012
    29
    bump
    27,097
    You need to do more of your own research.
    This is the corp that make the chips for the remote, which is just a leyless entry remote so could very well be for that car.
    Active Control :: Corporate Profile
    This is the remote in question.
    Keyless Entry Remotes at Remote Superstore
    So where are you at with it at the moment, as in, you replaced the relays, says it starts but does it stay running, have you cleared the errors shown now the relays have been replaced, then you can work on the errors left over.
    Mar 2012
    29
    It starts but immediately dies. The immobolizer light keeps flashing.
    I replaced all of the relays under the ECU box. Cleared the errors, but the same errors return.
    The remote that I found is not related to my audi at all.
    Is there a way to check that the ECU is working properly?
    I have 3-4 different tools for reading the SKC but none of them is working...The error that I get is ECU not found
    27,097
    If you still have all these errors, then you need to trace them 1st imho, could be the the relays have been fried which inturn has damaged some wiring & possible modules like the central electrics board, as to fry all those relays at once needs a fair amount of load, which I can only wonder what other damage its done.
    Mar 2012
    29
    My friend cleared the codes again and here is what we got.
    Strangely enough the VIN numbers don't match.
    Monday,26,March,2012,17:49:23:46862
    VCDS Version: Release 10.6.0
    Data version: 20100630
    Chassis Type: 8E - Audi A4 B6/B7
    Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
    69 75 76 77
    Address 01: Engine Labels: 06C-909-559-ASN.lbl
    Part No SW: 8E0 909 559 D HW: 8E0 909 059
    Component: 3.0L V6/5V G 0004
    Coding: 0016751
    Shop #: WSC 63351 000 00000
    VCID: 366824867E1D6BAC
    No fault code found.
    Coding: 0001002
    Coding: 04497
    Shop #: WSC 06435
    1 Fault Found
    35-00 - -
    Coding: 00000
    Shop #: WSC 00000
    3 Faults Found
    35-00 - -
    Coding: 00001
    Shop #: WSC 00000
    4 Faults Found
    35-00 - -
    Address 15: Airbags Labels: 8E0-959-655-84.lbl
    Part No: 8E0 959 655 A
    Component: Airbag 8.4E 5000
    Coding: 0010607
    Coding: 01141
    Shop #: WSC 00000
    3 Faults Found
    35-00 - -
    Coding: 03200
    Shop #: WSC 00000
    6 Faults Found
    30-00 - Open or Short to Plus
    01314 - Engine Control Module
    01315 - Transmission Control Module
    01304 - Radio
    Coding: 00002
    Shop #: WSC 63351
    6 Faults Found
    35-00 - -
    Address 45: Inter. Monitor Labels: 8E0-951-177.lbl
    Part No: 8E0 951 177
    Component: Innenraumueberw. 0604
    Coding: 00001
    Shop #: WSC 00000
    VCID: EBDE45F2F5DF6644
    Coding: 28220
    Shop #: WSC 05141
    Part No: 8E1959801
    Part No: 8E1959802E
    Part No: 8E0959801A
    Part No: 8E0959802A
    14 Faults Found
    35-00 - -
    35-00 - -
    00962 - Alarm via. Tilt Sensor
    35-00 - -
    35-00 - -
    35-00 - -
    35-00 - -
    Address 55: Xenon Range Labels: 4Z7-907-357.lbl
    Part No: 4Z7 907 357
    Component: dynamische LWR D07
    Coding: 00060
    Shop #: WSC 63351
    VCID: 040C8E4E7841093C
    Coding: 00211
    Shop #: WSC 00000
    1 Fault Found
    27,097
    I'm just restating whats already been advised, you will need to spend some time tracking down the issues, to many errors to be of help via the forum, needs hands dirty & maybe some spare modules to test with, eg. CE board.
  1. s3 immobilizer problem
    By rob irl tdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th February 2012, 08:32
  2. Help - Immobilizer light still flashing
    By harps21k in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th October 2010, 20:59
  3. Immobilizer flashing
    By keny in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th January 2010, 18:10
  4. Audi 90 stalls in park or neutral
    By imported_jimmy154 in forum Classic Audi Forum
    Last Post: 6th March 2005, 19:14
